Spare tire mounting issue - JeepForum.com
post #1 of 8 Old 03-03-2012, 03:11 PM Thread Starter
dkasparaitis
So after about 15 years of driving around with the stock spare tire I decided to put the correct size spare tire (31 X 10.5) on my jeep. I will be using the stock tire carrier but I have reinforced the tailgate and replaced the hinges with new ones.
The problem is the tire barely contacts the top two rubber bumpers and it's even worse on the bottom two. I know I want the tire to be tight on these pumpers to reduce stress on tailgate so im going to make some spacers out of some rubber sheeting I have.
My question is how much compression do you want on the bumpers and should the wheel make contact with the tire carrier when it's all tightened down? Basically, do I want 4 or 5 points on contact?
As an aside, after years of lurking around here for free I have decided to overcome my chronic cheapness and become a full member.
Also, this the first question I have posted on here so it's a pretty big day for me.
dkasparaitis is offline
post #2 of 8 Old 10-18-2013, 10:27 AM
Jeremy89
Question, how did you reinforce your tailgate?
Jeremy89 is offline
post #3 of 8 Old 10-18-2013, 10:58 AM
jbolty
jbolty's Avatar
You just need enough pressure so the tire does not flop around. Have someone look and move it by hand to make sure there is no daylight between the tire and the snubber. If I had to put a number on it I would say squash it about 1/4 inch.
I had a 31" tire on my stock tailgate for a few years with no problem and no damage. But, I was starting clean with no prior damage.
jbolty is offline
post #4 of 8 Old 10-18-2013, 11:59 AM
bpounds
bpounds's Avatar
This is interesting to me because I just dealt with the issue myself. I also have 31x10.5 tires. On mine, the bumpers were too tall for that tire and I could barely get the lug nuts started on the hanger studs. I actually tried an aftermarket spacer, but didn't like that. I ended up taking the bumpers off and cutting 1/2" off of each. Now I have nice firm contact with the bumpers, and the wheel is seated firmly against the hanger plate, which I think is ideally what you want.
So my issue was exactly opposite of what you're seeing. On yours, makes me wonder if someone has already cut down the bumpers.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #5 of 8 Old 10-18-2013, 12:45 PM
jbolty
jbolty's Avatar
probably different rim backspacing
jbolty is offline
post #6 of 8 Old 10-18-2013, 01:24 PM
bpounds
bpounds's Avatar
Very possible. My wheels are stock '88 Alum.
Just realized, this thread is 1 1/2 years old.
Bill
bpounds is offline
post #7 of 8 Old 10-18-2013, 01:34 PM
Andrews98TJ
Hey can you fit a yj top on a TJ?
Andrews98TJ is offline
post #8 of 8 Old 10-18-2013, 01:38 PM
Jeremy89
Yeah I have a tj (2003) and I have the space to mount my 33 inch spare if I lift the 3rd taillight and 1 1/2 inches, I just worry about it warping the tailgate
Jeremy89 is offline
spare tire , tailgate , tire bumpers
Spare tire mounting ? george318i TJ Wrangler Technical Forum 27 12-12-2008 07:56 PM
Spare tire mounting PANY TJ Wrangler Technical Forum 4 11-04-2008 04:21 AM
Spare Tire Mounting? GreyfoxVt YJ Wrangler Technical Forum 19 04-07-2008 12:57 PM
mounting spare tire in tub?? yellowismellow TJ Wrangler Technical Forum 3 02-28-2007 11:20 AM
Mounting a Spare 31" tire? krazykarguy TJ Wrangler Technical Forum 6 12-21-2004 11:04 AM
