Spare Size ?? - JeepForum.com
post #1 of 9 Old 02-03-2006, 01:10 AM Thread Starter
blevinsbulldog
Spare Size ??
Im Running 33x12.50's & My Spare Is Stock, If I Get A Flat Im Screwed. So I Was Wondering Will My Talegate Hold Up If I Mount A 31x10.50 On It ? If So Will I Be Allright Running 1 --31 & 3 --33's For A Week Or So Untill A New Tire Comes In . (IF IT CANT BE FIXED) I Have Road Hazzard That Covers Anything That Cant Be Repaired & I GET A NEW TIRE FREE OF CHARGE , But Takes About A Week To Get The Tires In (not In StocK)
I HAVE OPEN FRONT & REAR AXELES
95' RIO GRANDE
2.5 AKA THE SCREAMING HAMSTER
REAR TRACK BAR REMOVED
1 1/4 SHACKLES---3''BL
33X12.50 BFG A/T
GREEN JEEP CLUB MEMBER # 176
blevinsbulldog is offline
post #2 of 9 Old 02-03-2006, 05:23 AM
jrnjay
jrnjay's Avatar
With open rears you'll have no problem other than looking funny and if you need to get home who cares about looks
John
1991 YJ Black 2.5 5speed 3.5" Fabtech lift 32x11.50 Dunlop Mud Rovers
It's not what you don't do it's how you don't do it that counts!!!
jrnjay is offline
post #3 of 9 Old 02-03-2006, 07:33 AM
oct7brian
oct7brian's Avatar
I have a 32 spare on my gate and have no problem. Like what he says might look weird but who cares if you get home
1998 Grand Cherokee 5.9 Limited Edition, Upcountry Suspension for Now, Infinity Sound, NP 242 Swap
2002 Jeep Liberty Sport 4x4 3.7L Auto
1998 TJ 4.0 Auto Sahara Package 4" Suspension Lift 33 BFG Hard & Soft Top
oct7brian is offline
post #4 of 9 Old 02-03-2006, 07:58 AM
Rodeo1488
By These Things I Stand !
Rodeo1488's Avatar
Just take it easy and don't run too hard, and a 31-32 should be okay. I wouldn't run one longer than a week or so. You'll probably want to get an alignment when you get the new tire installed.
White Jeep Club Member #1488
"Sometimes, there's Justice.......Sometimes, there's Just Us. "
- Living my life on a Thin Blue Line -
Originally Posted by HolidayJeep
If that doesn't work, here's what you do. Buy a bunch of burritos and tie them to pieces of string. Then tie the strings to your Jeep. Then, when the meskins come out of the house drawn by the smell, you drive away. The meskins will chase burritos for miles and miles.
Rodeo1488 is offline
post #5 of 9 Old 02-03-2006, 08:20 AM
blake989
I've carried a 31" spare out back for quite some time. The only problem thus far is I have to lift up on the tailgate to shut it.
The YJ is no longer my DD. I have sacrificed all future retirement plans for jeep parts. I'm depending on social security!
blake989 is offline
post #6 of 9 Old 02-03-2006, 06:14 PM
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
I've heard that a tire within 3 inches of the rest is ok for temporary use, with open diffs.
- 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
- Donated drive train to the YJ, Parted out the rest
- Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline
post #7 of 9 Old 02-04-2006, 01:20 AM Thread Starter
blevinsbulldog
ive got stock wheels , so is there anything special that i need to do. i think i will have to take my 3rd brake light off or extend it. but it looks like i will have to cut the rubber bushings , is this so ?
95' RIO GRANDE
33X12.50 BFG A/T
post #8 of 9 Old 02-04-2006, 06:39 AM
RCHavok797
RCHavok797's Avatar
I have a 31 inch tire mounted on a stock wheel that I use as my spare and I didn't have to modify anything to make it fit. The only thing you will probably need to do is extend the third brake light like you mentioned already.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline
post #9 of 9 Old 02-04-2006, 10:46 AM Thread Starter
blevinsbulldog
big thanks to all
95' RIO GRANDE
33X12.50 BFG A/T
What size of spare do I need to use? OzarkOutdoors TJ Wrangler Technical Forum 24 03-15-2010 08:36 PM
Spare Rim size denalione YJ Wrangler Technical Forum 1 04-18-2009 02:30 PM
What size spare? rdhclark TJ Wrangler Technical Forum 5 11-21-2008 10:47 PM
Spare different size Morgen251 TJ Wrangler Technical Forum 43 07-18-2007 09:34 AM
off size spare? monkeychrist TJ Wrangler Technical Forum 7 07-15-2007 04:21 PM
