Southern Jeep back up North - JeepForum.com
post #1 of 4 Old 01-14-2012, 01:36 PM Thread Starter
andybloch1
So the PO of my YJ unhooked the heater core for some reason (probably because the heat stopped working at some point and never fixed it being that he lived in Florida)
So now I need to know how the heating system under the hood was originally hooked up. Right now I see the the inlet and outlet of the heater core sticking through the firewall hooked up to nothing. Where are the radiator/coolant lines supposed to run? Pics of a "stock" system would be great.
Thanks
Never ascribe to malice, that which can be explained by incompetence.
óNapoleon
andybloch1 is offline
post #2 of 4 Old 01-14-2012, 03:06 PM
moonshinefuel
The inlets and outlets are both different sizes, so when you hook them into the water pump area, they will be different sizes there too to get them back to factory directional coolant flow through the heater core.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #3 of 4 Old 01-20-2012, 09:42 AM Thread Starter
andybloch1
can you describe the whole circuit. Radiator to water pump to etc.?
Or better yet, take a photo of how it is arranged in your engine.
óNapoleon
post #4 of 4 Old 01-20-2012, 04:36 PM
dodger889
Look for a smaller hose about an inch around making a loop passenger side of the engine. One should be right where the thermostat housing is. The other is coming from the water pump just beside the other.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
Southern CT Jeep shops? 2ndmardiv Wrangler General Discussion 7 04-29-2010 01:40 AM
Reputable Jeep shop in Southern Virginia JackMJeep Wrangler General Discussion 11 09-13-2009 09:45 AM
Southern Jeep Build kylester0 TJ Wrangler Technical Forum 6 01-08-2009 03:42 PM
Southern NH Jeep Wrangler Mechanics? Rick5150 TJ Wrangler Technical Forum 2 01-28-2008 09:35 AM
North GA/SE TN/North Ala/West Carolina Family Bar Swap . . MCG DAWG YJ Wrangler Technical Forum 4 01-10-2007 12:28 PM
