Sound bar - JeepForum.com
post #1 of 32 Old 04-03-2013, 04:58 PM Thread Starter
flea1987
Sound bar
So been thinking about eliminating my radio all together (gets no reception and I don't really listen to much radio) and installing a sound bar with an audio jack in it's place.
Something like this:
http://www.autoaccessoriesgarage.com...Fcc-MgodjgwARg
Only problem is I can't find one that comes with an audio jack installed. Anyone know how this can be done? Don't want to rewire one made for in home use to make it work in the jeep. Thanks
flea1987 is offline
post #2 of 32 Old 04-03-2013, 05:06 PM
Reno72
Seems to me it might be cheaper if your speakers are in good shape to change the head to a new one which accepts a jack. That's what i'm doing because between Pandora and all my CD's on the Iphone I don't need no stinkin radio or CD player. They are pretty cheap right now.
Reno72 is offline
post #3 of 32 Old 04-03-2013, 05:38 PM Thread Starter
flea1987
you mean the entire cd player right? was wanting to eliminate that for space for future switches.....
flea1987 is offline
post #4 of 32 Old 04-03-2013, 05:40 PM
Xpress
You need an amp to drive the speakers, your mp3 player doesn't put out nearly the power required to drive the speakers properly. From there you can play your mp3 through the amp.
All about that unibody life.
Xpress is offline
post #5 of 32 Old 04-03-2013, 05:49 PM Thread Starter
flea1987
That's the kind of answer I'm looking for, knew the ipod wouldn't even try to make an output on the speakers, just didn't know they mad an amp with an audio jack
flea1987 is offline
post #6 of 32 Old 04-03-2013, 05:51 PM
Xpress
Usually they don't, you will have to do a bit of googling. The amp also needs the signal lead to be hooked into a 12v power source (make sure you add a fuse to this lead, and a switch so you can turn the amp on and off). It's not that difficult to do, just takes a bit of brain power and some research first.
Xpress is offline
post #7 of 32 Old 04-03-2013, 06:01 PM Thread Starter
flea1987
flea1987 is offline
post #8 of 32 Old 04-03-2013, 06:17 PM
Chrisnvegas
INFIDEL
Chrisnvegas's Avatar
Here is a non complicated answer.
Buy a quality amp, get a RCA to 1/8" cable. Turn the gain up on the amp and use the mp3 player to control the volume. If you want to get fancy, you can install a jack and volume knob in-dash.
I hate computer updates
Chrisnvegas is offline
post #9 of 32 Old 04-03-2013, 06:21 PM Thread Starter
flea1987
That seems simple enough. Now it's time to see how many speakers can get blown up
flea1987 is offline
post #10 of 32 Old 04-03-2013, 06:48 PM
linusb
My goal was same as yours. I bought this one a couple years ago.
http://www.amazon.com/Jeep-Wrangler-...jeep+sound+bar
All it has is male micro-jack for input. It's kind of cheap and generic but it does a pretty good job. It ain't exactly high sound quality but volume is good. I remember being ticked off when I first bought it because the sound volume was barely audible. I cursed and stomped thinking I got ripped off and then realized the volume on my iphone had to be turned up. Been happy with it since then.
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline
post #11 of 32 Old 04-03-2013, 06:56 PM Thread Starter
flea1987
Did you have to wire it in? JW, don't see any wires in the picture.
Maybe you can post a better one of yours.
flea1987 is offline
post #12 of 32 Old 04-03-2013, 07:27 PM
linusb
Yeah, it had 3 wires coming from it. 1 red for 12v feed, 1 ground, and 1 with the microjack already attached. Easy Peasy. I'll see about posting other pics. For the price, pretty hard to beat.
linusb is offline
post #13 of 32 Old 04-03-2013, 07:39 PM Thread Starter
flea1987
well the stock picture is garbage and can't really tell much from it. Can you hook up the stock speakers to it as well, or not so much?
flea1987 is offline
post #14 of 32 Old 04-03-2013, 07:46 PM
Firefyter-Emt
A really good place to look is towards marine amps. They also have a lot of radios with either non-standard sized head units, or surface mount remote controls. A hidden mount control box and a small remote volume and mini controller is a great way to go. Even if you want a standard dash radio, Crutchfield has a few great marine units that can even stream via Bluetooth!
Firefyter-Emt is offline
post #15 of 32 Old 04-03-2013, 08:03 PM
Firefyter-Emt
http://www.crutchfield.com/p_020M502...2.html?tp=1721
This is the one I am thinking of... Rain "safe" and I can stream audio from my iPhone via Pandora! Sure, you can't play CD's... but I can't play cassettes or 8-tracks either!
