sometimes start sometimes wont - JeepForum.com
post #1 of 4 Old 06-22-2013, 09:34 AM Thread Starter
yj94lapain
Have a 94 yj and about tp go crazy with his starting issue sometimes it will start and sometimea it wont it can be hot and start thatn not start and same with it being cold any ideas and i uave bran new sparks coil wires and d cap
yj94lapain is offline
post #2 of 4 Old 06-23-2013, 05:06 AM
DEERSLAYER94YJ
Before the starter went in my 94 I had the same symptoms. When it wouldn't turn over I'd have to reach down and give the starter a good tap with the o'l hammer, then she'd fire right up. If this isn't your issue then clearly you have a loose connection, I'd start at the terminals and go from there. Hope this helps bud...
Nightcrew Member #093
DEER--- It's whats for supper!!
DEERSLAYER94YJ is offline
post #3 of 4 Old 06-23-2013, 04:34 PM
TSEJEEPERS
When you say sometimes it will not start, will it turn over or just nothing?
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #4 of 4 Old 06-23-2013, 04:40 PM
jimbos76cj
Won't start or won't crank? If it won't start look under your dash there should be a ground wire attached to your parking brake pedal assembly. I had one not start do to the bracket braking from the side of the tub. So e times it would make contact and some times it wouldn't.. I think the wire runs the fuel pump. Probably not if but may be worth the look.
88 YJ 35's 8.8 rear, family style roll bar, ax-15 external slave conversion, Custom double D fab dash 4" of lift taurus fan, Head light wiring upgrade, MSD 6al, JB conversions SYE, 258 with RV cam, Long tube headers, Borla exhaust. 1"mm, Auto meter gauges.
jimbos76cj is offline
