Something's Bent - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Something's Bent
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 10-21-2015, 04:33 PM   #1
Gozz
Something's Bent
Hey guys so a few days ago I got into a bit of a crash.
The guy hit my front driver tire and now when I drive the Jeep it kind of pulls me to one side. If I hit a bump the Jeep really pulls and goes kind of out of control. Sometimes though if I'm going straight it doesn't pull at all and feels normal, but it just feels sort of random, unless it's a bump, then it feels pretty bad.
I was looking under the car to see if I could find any obvious bends, and the only thing I could really see is my Track Bar being slightly bent (but I think it's supposed to be kind of bent?), it also has a scratch going through it, which is why I think it could be that.
Other than that I don't see anything obvious. You guys have any ideas what it could be?
I'll leave a picture to show what I see and I'll take more if you guys need, but I don't think the pictures will help very much if can't even tell in person.
Also my power steering pump is leaking from the bottom, especially when the tires are turned all the way to the right, which is why my axle is all wet.
I think I had this from before but maybe it became worse?
Gozz is offline   Reply With Quote Quick reply to this message
Unread 10-21-2015, 05:47 PM   #2
cyoos
Jack it up and see if there's slop in the assembly by pushing-pulling the tire at different points. The impact might have trashed your hub or a ball joint. I wouldn't think it would be a tie rod end, but I wouldn't rule out that possibility either.
cyoos is offline   Reply With Quote Quick reply to this message
Unread 10-21-2015, 06:13 PM   #3
gotswap
Pretty much a full inspection, wheel bearing, ball joints, tie rod joints, might measure the C to be safe, track bar, bushings, steering box and mount. If it moves or is part of the steering it needs to be checked.
gotswap is online now   Reply With Quote Quick reply to this message
Unread 10-21-2015, 07:01 PM   #4
Drednot
Drednot's Avatar
Take a pic from way back and then zoom in to get the whole front axle. that eliminates the distortion from the wide angle lens.
Best to take it to an alignment shop for a check on their machine. Ive seen where the rear of one spring leaf and the hanger bent ever so slightly and caused the same random steering.
It depends on the direction and location of the hit as to where the greatest force and weakest link intersect.
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35
12 Cherokee 4x4,3.7L,
"Non Vi Sed, Arte"
Drednot is offline   Reply With Quote Quick reply to this message
Unread 10-21-2015, 09:29 PM   #5
DirtKar
I pledge allegiance.
DirtKar's Avatar
Yes, your track bar is scratched and must be removed. You'll thank me later.
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline   Reply With Quote Quick reply to this message
Unread 10-21-2015, 10:18 PM   #6
bruinjeeper
^ beat me to it. Dang you're on lately Dirtkar.
Also, follow Dred's advice - if he hit your tire (from what i understood) alignment, ball joints, and hubs should be inspected - like soon, like now. DOn't let this go because its 'random' and sometimes 'its fine'. You're experiencing some bumpsteer, and that can turn into a real panic situation if you let it slide.
CHeck back with us and let us know what was found to be the culprit(s) (i think its going to be greater than one)
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
bruinjeeper is offline   Reply With Quote Quick reply to this message
Unread 10-22-2015, 12:10 PM   #7
rustisexpected
I did not see it mentioned yet but check your springs and shackles out as well.
Rusty's build thread - http://www.jeepforum.com/forum/f22/project-jermey-1806881/
rustisexpected is offline   Reply With Quote Quick reply to this message
Unread 10-22-2015, 12:41 PM   #8
Gozz
So basically it's pretty hard to find out without the help of a shop then? Makes sense.
Nothing seems too far out of whack just from view so I don't know how to check each part individually for a fault.
Here's what I could get of the front more zoomed out, I also added a picture of the driver side tire, since that's where I was hit:
Unread 10-22-2015, 06:22 PM   #9
Drednot
Drednot's Avatar
It looks like the drivers side tie rod arm of the knuckle is twisted and the tapered stud is now tipping outward. Jack the front up to take weight off the wheels and have you biggest gorilla of a friend try to rip the wheels off while you wrap your hand around every joint feeling for loose movement.
I'd still put it on a machine after replacing any loose hardware.
"Non Vi Sed, Arte"
Unread 10-22-2015, 08:53 PM   #10
Gozz
Thanks Drednot.
Just be to sure, are you talking about this part:
Unread 10-22-2015, 10:15 PM   #11
DirtKar
DirtKar's Avatar
Originally Posted by Gozz View Post
Thanks Drednot.
Yes.
And while you're under there, let's get rid of these items as well, shall we?
YJOTM JULY 2014
Unread 10-22-2015, 11:41 PM   #12
Drednot
Drednot's Avatar
Originally Posted by DirtKar View Post
Yes.
That's not going to fix his problem. Probably make it worse till its fixed.
Yes, That's what I was seeing.
"Non Vi Sed, Arte"
Unread 10-23-2015, 07:13 PM   #13
Gozz
So I took it to a shop.
Basically the mechanic told me that the gearbox needs a rebuild and that's why it feels like it's pulling, something in there is loose, and now more loose after the accident. He said that other than that he doesn't really see anything. I was suspecting more of the tie rod or something in the wheel being bent. He also said it probably needs an alignment.
Is what he is saying just? Is the gearbox making my jeep feel squirrelly?
For everything after taxes and whatever else, he's asking like $500 for a gearbox rebuild and some other misc things.
I know that sounds like a lot, but there's no way in hell I can do a gearbox rebuild.
Unread 10-23-2015, 08:18 PM   #14
DirtKar
DirtKar's Avatar
He said its bent. And it's useless. And heavy. And it's ugly. Besides, how many SOA guys are running either or both of those items? Drag link angle is high to me and he's describing bump steer.
OP, did you get a chance to check your wheel for play in the 9-3 o'clock and the 12-6 positions?
$500 is a lot of money for an item to be rebuilt when new can be had for much less without being a huge mechanical challenge. What were the other items you were referencing that were also going to be addressed at that estimate?
As for it probably needing an alignment, it probably does. Also an easy fix that you can do yourself.
Here ya go, courtesy of MeanMax.
http://www.jeepforum.com/forum/f12/b...gnment-994928/
YJOTM JULY 2014
Unread 10-23-2015, 09:53 PM   #15
gotswap
You need to find a different mechanic, that drivers side knuckle is bent/twisted where the tie rods attaches, it should be vertical..... At the very least you are looking at a new knuckle and tie rod end but I would bet one or both ball joints is shot as well as the wheel bearing.
