Something with the clutch - I think . . . - JeepForum.com
post #1 of 8 Old 05-16-2010, 09:31 AM Thread Starter
Cyborg
I was headed up the road last night after taking off from a light. I made it about two blocks, everything seemed fine. Then I lost all power to the wheels (front only, rear drive-shaft is out right now). I gave it some more gas, rev's went up, and so did the spedo reading.
So, Im wondering what could have happened. I went back and checked this morning.
the 4x4 light was out on the dash, but Im wondering if this is because I took it out of 4x4 last night to try to get it rolling again, and putting it back in 4x4 the front vacuum disconnect hasn't engaged yet.
I pulled the vacuum lines off the axle disconnect, and there was no suction when I had the t-case in 4x4. There was however suction at the t-fitting that line goes to on the intake manifold.
My other thought was the clutch wont engage. I checked the reservoir, it is still full. There is no leaks on the master, lines, or slave.
With the transmission in neutral, and the t-case in 4x4, with the rear drive-shaft off, and front drive-shaft connected (but the 4x4 light out), the output yokes from the t-case spin about 1 revolution per 8 seconds. Something strange here, or is this normal if there is no torque load on the driveline?
95 Jeep YJ
2.5L
AX-5 from a late 90's TJ
thanks everyone
Cyborg is offline
post #2 of 8 Old 05-16-2010, 10:04 AM
RockWoRM
RockWoRM's Avatar
Not sure why your rear line is off/out, but I'd try in gear power to see if the front shaft is ok, if so, they I'd go back to your vac. system. It is also possible the TC poped into neutral... double check that. Sometime the simplist things are the culpret.
WRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #3 of 8 Old 05-16-2010, 10:33 AM Thread Starter
Cyborg
Just have the rear shaft off to get a new one cut and balanced for the new SYE.
I put the tranny in any gear and the front shaft just spins (I believe because the front vacuum is not engaged.)
For the axle disconnect coupling to engage, does the jeep need to be moving, or should the axle-shaft rotate and couple up? and if the jeep needs to be rolling can I try pushing the jeep backwards? Will that be enough force to have it couple back up? I'd like to hopefully eliminate at least one piece of the puzzle and go from there.
Cyborg is offline
post #4 of 8 Old 05-16-2010, 03:58 PM Thread Starter
Cyborg
bump?
10char
Cyborg is offline
post #5 of 8 Old 05-16-2010, 10:15 PM Thread Starter
Cyborg
Ok, I pulled the vacuum line connections off the disconnect again, and got no vacuum on either line in 2WD or 4WD.
So, I pulled another vac line, and plugged it up to the correct port to engage the front axle shaft, and I was able to move.
I'm not sure what controls/operates the vacuum going to that disconnect, any ideas?
My only thoughts are the plug in the t-case where the 4 lines go.
Cyborg is offline
post #6 of 8 Old 05-16-2010, 11:40 PM
ImpactFabWorks
sounds like the switch in the t-case went bad. it's a cheap an easy fix and the only thing i can think of.
1990 YJ = The Toy/ My Daily Driver
1996 XJ= Wifes Daily Driver
Please fill out your profile, It helps us help you!!!
ImpactFabWorks is offline
post #7 of 8 Old 05-17-2010, 03:52 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
This.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #8 of 8 Old 05-17-2010, 05:38 PM Thread Starter
Cyborg
Ordered the part tonight. It was damn cheap. $11 my cost. Hoping it works.
Cyborg is offline
TJ AX-15 is difficult to shift! Replace clutch, clutch & rebuild, or just suck it up! NORCALROOTS TJ Wrangler Technical Forum 38 12-12-2015 09:07 AM
88 5 Speed - Tranny Not Engaging After Clutch install (no clutch need to shift) kgillette YJ Wrangler Technical Forum 12 11-01-2009 12:39 PM
clutch whirrring/squealing noise - but stops when I press on clutch dirtyjpwrangler JK Wrangler Technical Forum 12 09-28-2009 08:55 PM
Question about destroying clutch plate WITH CLUTCH PEDAL DEPRESSED JeffB TJ Wrangler Technical Forum 12 07-20-2009 10:29 AM
great! More AX5 Clutch problems!!!!! hooray for internal clutch slave cylinders! Big-n-Broke-YJ YJ Wrangler Technical Forum 6 08-19-2008 02:14 PM
