solution for stripped torx bolts - JeepForum.com
post #1 of 16 Old 05-26-2008, 12:14 AM Thread Starter
YJ_95
ok so i tried to take my windshield frame off and managed to strip 3 of the torx blts on the hinge. What can i do to get these out. Welding isnt an option so what else can i do. Need suggestions please!!! Thanks!
YJ_95 is offline
post #2 of 16 Old 05-26-2008, 12:17 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Lower or upper bolts??? On the windsheild, Take it by a muffler shop or an auto shop you trust and have them tack on some nuts.
Lower, pull the dash apart and get in behind to try and loosen the nuts on the end of the bolts.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #3 of 16 Old 05-26-2008, 12:20 AM Thread Starter
YJ_95
But i cant really spend anymore money and im sure taking it to a muffler shop would cost something. also Can i just drill them out with a diamond tip drill bit? Im buying all new bolts anyway. only the upper ones.
YJ_95 is offline
post #4 of 16 Old 05-26-2008, 12:23 AM
rustywrangler
If you have the ability to retap the upper ones you could, but the upper bolts have a nutstrip backer that is loose on the inside. Kinds sits in a grove to keep it in place.
There is no access to the upper bolt holes at all, that is why drilling is a last resort.
Have you tried the easy outs????
post #5 of 16 Old 05-26-2008, 12:24 AM Thread Starter
YJ_95
what are the easy outs?
YJ_95 is offline
post #6 of 16 Old 05-26-2008, 12:30 AM
rustywrangler
Easy outs typically are reverse thread drillbits. You drill out the chewed up torx threads then use the other end of the bit to bite into the bolt and it backs it out. Check out sears.com. They list the craftsman set.
post #7 of 16 Old 05-26-2008, 12:35 AM Thread Starter
YJ_95
ok thanks i will check it out. Are they called easy outs or is there a specific name?
YJ_95 is offline
post #8 of 16 Old 05-26-2008, 12:40 AM
rustywrangler
Last I knew they were easy outs.
post #9 of 16 Old 05-26-2008, 12:43 AM Thread Starter
YJ_95
k i will definatly check it out. Thanks for the help.
YJ_95 is offline
post #10 of 16 Old 05-26-2008, 02:01 AM
BlueOvalBoy
Did you totaly strip them out or just enough that the ratchet slips and the bit won't grab? I had this happen when I was removing a bad passenger seatbelt. I tried using my impact gun and it actually worked! I was able to get it out fairly easily. My next option was the tack weld idea.
BlueOvalBoy is offline
post #11 of 16 Old 05-26-2008, 06:17 AM
xeastend
Easy out is a generic name.I think they are called Bolt extractors.Any decent salesperson will .know
http://www.sears.com/shc/s/p_10153_12605_00966196000P
xeastend is offline
post #12 of 16 Old 05-26-2008, 06:33 AM
rustywrangler
Thanx for the clarification, When I bought my set, I didn't pay attention to the actual name.
post #13 of 16 Old 05-26-2008, 06:50 AM
xeastend
Check these out.Never used them,but looks interesting.Dont think there is drilling involves like easy outs
http://www.sears.com/shc/s/p_10153_12605_00953153000P
xeastend is offline
post #14 of 16 Old 05-26-2008, 11:05 AM Thread Starter
YJ_95
ok thanks but the only problem is there 60 bucks. im limited to money so i will probably get a single bit instead of the whole set.
YJ_95 is offline
post #15 of 16 Old 05-26-2008, 11:19 AM
havasu
On permanent vacation
havasu's Avatar
My advice is to make sure you get a good quality type of screw extractor. I once bought a cheap one which broke out inside the bolt I was trying to remove. It compounded my problem severely.
havasu is offline
HELP! Stripped torx bolts on window hinge distantdog TJ Wrangler Technical Forum 42 05-11-2011 02:07 PM
Help Please...Stripped Torx bolts in windshield frame. Prryan45 TJ Wrangler Technical Forum 10 09-08-2009 10:04 PM
More stripped torx bolts? Deadhorse TJ Wrangler Technical Forum 3 05-21-2009 07:50 AM
Stripped Torx Bolts! (removal & replacement?) Bethlehem TJ Wrangler Technical Forum 10 11-02-2008 12:49 AM
Removing stripped Torx bolts voigtrobert TJ Wrangler Technical Forum 2 02-18-2006 12:57 AM
