solid passenger side shaft question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > solid passenger side shaft question
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 06-04-2013, 05:34 PM   #1
Unclejimbo
So I have everything installed my alloy seals on the end of the tubes I have the passnger side shaft and driverside shaft in. I was testing things without the hubs on and i think something is wrong just cant figure out what it is, unless its all correct and im just dumb. But anyway when i rotate the driveshaft by hand obviously the driverside axle spins however the passnger side doesnt, when I rotate the passenger side shaft the driverside also turns but the driveshaft does not. I can get it all to rotate together as long as I have pressure on the passenger side axle. I just wanna make sure im not over thinking this before I go putting everything back together. Thanks for any help.
Unclejimbo is offline   Reply With Quote Quick reply to this message
Unread 06-04-2013, 05:41 PM   #2
Unclejimbo
nevermind i got it, and sadly i dont know how to remove threads so sorry for the clutter.
