Solid/non-blinking left turn signal - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Solid/non-blinking left turn signal
3" BDS Suspension Lift Kit - Jeep JK 07-11Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep Wrangler Weatherstripping
Unread 08-13-2015, 04:24 PM   #1
4G64
I searched and couldn't find anything similar. When I hit the left turn signal switch, both the dash light and taillight go solid. Right side doesn't have the same problem. Relay maybe?
4G64 is offline   Reply With Quote Quick reply to this message
Unread 08-13-2015, 06:39 PM   #2
dancytron
There isn't a relay.
Many goofy tail light/brake light/blinker issues can be solved by cleaning the bulb sockets and putting in new grease and cleaning the ground points for the tail lights. The tail lights ground through their mounting bolts, to unbolt them and clean up where they mount until it is nice and shiny.
Since it works for the right hand side, it doesn't sound like the flasher (on the top of the fuse box below the driver's side dash) but you can switch it with the other one that drives the hazard lights to check.
If that doesn't work, you got a short somewhere.
dancytron is online now   Reply With Quote Quick reply to this message
Unread 08-14-2015, 04:43 AM   #3
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
You don't mention the front light... A burned out bulb can give those symptoms.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 08-14-2015, 06:23 AM   #4
Que89YJ
The turn signal flasher can is a relay. Try swapping it.
Que89YJ is online now   Reply With Quote Quick reply to this message
Unread 08-14-2015, 06:36 AM   #5
Mike Romain
That can be deceiving though. Some newer electronic flashers will still flash no matter the load so you can't tell if a bulb is out.
Mike
Unread 08-29-2015, 03:36 PM   #6
4G64
Ended up being a burnt out drivers side rear bulb. No broken filaments and I always thought that the turn signal would flash faster if there was a burnt bulb. Guess not. Anyway, thanks for the suggestions.
Unread 08-29-2015, 03:57 PM   #7
dancytron
I guess it is a relay, I've just never heard it called that.
Unread 08-29-2015, 04:13 PM   #8
Drednot
Drednot's Avatar
I'd call it a circuit breaker before I'd call it a relay.
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35
12 Cherokee 4x4,3.7L,
"Non Vi Sed, Arte"
Drednot is online now   Reply With Quote Quick reply to this message
Unread Yesterday, 12:21 PM   #9
Que89YJ
I call it a flasher or relay. I haven't heard it called anything else. As long as we are on the same page though. The silver can for the turn signals and e flasher. LOL
