solid axle swap bearing?? - JeepForum.com
post #1 of 7 Old 11-12-2013, 01:46 PM Thread Starter
kjg26
kjg26's Avatar
For those of you who have done a solid axle swap. What did you do with the bearing that is just in board of the Cad disconnect?
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #2 of 7 Old 11-12-2013, 01:50 PM Thread Starter
kjg26
kjg26's Avatar
My main concern is it won't be being lubricated anymore.
kjg26 is offline
post #3 of 7 Old 11-12-2013, 01:57 PM
SeanB95YJ
I haven't done it (I just slid the collar over and locked it in place), but my thought would be to remove that bearing and forget about it... the purpose of that bearing is to support the outer end of the inner shaft.... if you install a 1-piece shaft (TJ/XJ) then there's no shaft end to support at that location... you have the inner (splined) end going into the carrier and the outer end to the U-joint at the unit bearing.
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #4 of 7 Old 11-12-2013, 04:34 PM
kloppk
The "bearing" is actually a plastic bushing.
You can just pry it out with a screwdriver and toss it.
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline
post #5 of 7 Old 11-12-2013, 04:36 PM Thread Starter
kjg26
kjg26's Avatar
Even better
kjg26 is offline
post #6 of 7 Old 11-13-2013, 03:51 PM
Jeepsr4me
just leave it. The TJ or Cherokee shaft is smaller than the bearing. Dont even touch it.
Some are REAL roller bearings and others are these plastic collars with big teeth like a cog. Had both kinds.
Jeepsr4me is offline
post #7 of 7 Old 11-13-2013, 04:09 PM
thebull84
x2
thebull84 is offline
