solenoid? - JeepForum.com
post #1 of 8 Old 11-30-2011, 12:05 PM Thread Starter
HEDLOCUST
solenoid?
1988 wrangler laredo 4.2l theres a solenoid in the hose from the pcv with two wires ... im rerunning all the vacuum lines and was wondering what this is and if its needed ?
HEDLOCUST is offline
post #2 of 8 Old 11-30-2011, 12:45 PM
Berniebikes
Not needed, a recall removed these. It's a pcv shutoff. Get rid of it
Berniebikes is offline
post #3 of 8 Old 11-30-2011, 01:13 PM Thread Starter
HEDLOCUST
awesome thanks was just curious cuz i know its apart of the computer vacuum set up better safe then sorry
post #4 of 8 Old 11-30-2011, 08:38 PM
Mark05059
do the nutter bypass and you can get rid of alot of stuff (wires/hoses/computer)
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #5 of 8 Old 12-01-2011, 09:08 AM Thread Starter
HEDLOCUST
wtf is a nutter bypass? i keep hearing about it but dont know what exactly it is ....
post #6 of 8 Old 12-01-2011, 09:38 AM
ChicagoYJ
Yes, I Understand!
ChicagoYJ's Avatar
ChicagoYJ is offline
post #7 of 8 Old 12-01-2011, 10:54 AM
Berniebikes
the Nutter bypass is named for Nutter, someone who first came up with the idea. Essentially you modify your ignition wiring to take the fuel control for the electric stepper motor away from your carb and the ingition control away from your computer, so that you no longer have a closed loop emission controls system run by the ecm. Once you 'nutter' the vehicle, the ECM and everything connected to it no longer has any control of the vehicle ignition or fuel and can be removed if you choose. You can take out the pulse air tubes, the pressure solenoids and most of the vacum lines and junk running around the engine bay. Look at the links posted, or in the Frequently Asked Questions stickys at the top to get a full description and how to.
post #8 of 8 Old 12-01-2011, 01:22 PM
Que89YJ
Before doing the nutter you need to worry about the inspection. PA is a PIA! Please read and check before doing it. The nutter and team rush will make your Jeep run infinitely better BUT:
http://www.jeepsunlimited.com/forums...d.php?t=382695
Que89YJ is offline
solenoid mattman320 YJ Wrangler Technical Forum 1 05-21-2009 12:31 AM
Solenoid Optik45 TJ Wrangler Technical Forum 1 05-28-2008 11:19 AM
Bad Solenoid...Again Optik45 TJ Wrangler Technical Forum 0 05-27-2008 03:19 PM
1988 YJ What is this solenoid for? drespecki YJ Wrangler Technical Forum 9 01-16-2007 09:47 AM
my starter solenoid blew... can i simply replace the solenoid? hmk_21 YJ Wrangler Technical Forum 11 08-30-2006 01:34 PM
