sol vac solenoid - JeepForum.com
post #1 of 10 Old 04-20-2013, 02:33 PM Thread Starter
MCobb5
1987 YJ Wrangler
sol vac solenoid
I nuttered my 4.2l and was wondering if that eliminates the sol vac solenoid? If not where can i buy a new one?
MCobb5 is offline
post #2 of 10 Old 04-20-2013, 06:13 PM
Old4X
1990 CJ7
Not needed once nuttered
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #3 of 10 Old 04-21-2013, 09:04 AM Thread Starter
MCobb5
1987 YJ Wrangler
Did the nutter cause this to stop working? Or should it work, but its not need?
MCobb5 is offline
post #4 of 10 Old 04-21-2013, 10:46 AM
dancytron
The Nutter stopped it from working. It is controlled by an electric vacuum solenoid which is controlled by the computer (which the Nutter unhooked).
You can run a toggle switch to it and use to for manual high idle (handy on mine when it is really really cold). See http://home.sprynet.com/~dale02/control.htm
dancytron is offline
post #5 of 10 Old 04-22-2013, 09:41 AM Thread Starter
MCobb5
1987 YJ Wrangler
That is exactly what I was thinking about doing. Thanks for the advice!!
MCobb5 is offline
post #6 of 10 Old 04-22-2013, 01:40 PM
Fernando
Fernando's Avatar
1987 YJ Wrangler
Here is another idea for a manual high idle, in case you don't have the stock carb.
http://www.jeepforum.com/forum/f12/t...speed-1188723/
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline
post #7 of 10 Old 04-23-2013, 09:03 AM Thread Starter
MCobb5
1987 YJ Wrangler
Where did you buy the Vacuum parts. Are they off a certain model Car or are they just a generic model? If it is from a particular car, what model and make? I found out yesturday that my sol-Vac is bad!!
MCobb5 is offline
post #8 of 10 Old 04-23-2013, 09:21 AM Thread Starter
MCobb5
1987 YJ Wrangler
Do you have a MC 2000 Carb or Weber? It doesn't look like a Carter in this pic!
MCobb5 is offline
post #9 of 10 Old 04-23-2013, 12:15 PM
Fernando
Fernando's Avatar
1987 YJ Wrangler
I bought them at a local AC parts supplier, generic stuff nothing model specific...
I have a Weber
Fernando is offline
post #10 of 10 Old 04-23-2013, 03:35 PM Thread Starter
MCobb5
1987 YJ Wrangler
Thanks!
MCobb5 is offline
