Softtop Hardware (Full Steel Doors) - JeepForum.com
post #1 of 13 Old 04-08-2011, 12:39 PM Thread Starter
89WhyJ
I bought my YJ over a year ago with a hard top and full steel doors. I sold the hardtop since it was in pretty bad shape, and have been using just a bikini top since then. I know very little about softtops and their associated hardware. If I understand correctly, there were very few YJ's from the factory that came with full steel doors and softtops. I've been able to find most of the OEM hardware pretty cheap. Now, are there any replacement tops for a YJ with full steel doors to utilize the original hardware? I've looked at the pavement ends tops, and I like the $299 price tag. However, it looks like they only have them for YJ's with half doors. I could forget the hardware and go with a bowless top, but I was hoping to not drop over $400 into it. Comments? Recommendations?
89WhyJ is offline
post #2 of 13 Old 04-08-2011, 12:45 PM
sacrifice
I would recommend craigslist.
granny shifting not double clutchin like I should
'89 YJ Build Thread:
WhyJayPA's '88 Build: http://www.jeepforum.com/forum/f22/mean-green-build-college-budget-1164650/
sacrifice is offline
post #3 of 13 Old 04-08-2011, 01:25 PM
Berniebikes
Full steel doors will work with the Besttop replacement top, but you may get some leaking around the upper rear corners. It will seal ok, but not perfectly. Go to Quadratech and use their top selector and pick the type of hardware you have. OEM soft top hardware differs from the Bestop hardware, and the top you pick needs to match. There are several selections available based upon your hardware selection.
Berniebikes is offline
post #4 of 13 Old 04-08-2011, 02:27 PM
texas_yj
factory soft top hardware will not work with full doors, soft tops came with half doors and soft uppers, which had square corners, yours of course are rounded
super top hardware looks like it will work, but in fact doesn't, the radius of the curve is different. you'll either have to get ahold of 1/2 doors, or do the TJ soft top mod (TJ do work)
http://www.jpmagazine.com/featuredve...ras/index.html
Sold) 94 YJ, 4.0L 5 sp manual, Hard top, 33/12.50s, 4.10 ring&pinions, Polished D30 w/Aussie front, 8.8 rear w/ LS, 2.5" RC, 2" BL, 5/8" booms, TJ flares, SYE, custom F/R bumpers and rock sliders, 8k winch, dual optimas, HO alt.
2) (Sold) 99 TJ, mustang 5.0 GT 40, AX15/231J, trektop, 37x12.50r17 cooper STT, superlift 6" long arm, D30/44 w/ ARBs & yukons, customized warn bumpers, custom sliders, 12K winch w/ synthetic rope, custom paint
3) 2007 JKU being built now
texas_yj is offline
post #5 of 13 Old 04-08-2011, 05:00 PM Thread Starter
89WhyJ
Now I'm confused. What about this:
http://www.quadratec.com/products/11033_9406_07.htm
Granted, the link above is only for the front bows...but it seems like there is an option for full doors and a soft top. I've just never seen a top for a YJ and full doors.
89WhyJ is offline
post #6 of 13 Old 04-08-2011, 08:58 PM
muddy93
1987 FSJ Wagoneer
I've got a bestop supertop, it works just fine with full steel doors.
Actually, I just sold my hard top, got tired of storing it during the summer, and only have the supertop. It takes a little wile to warm up in the winter, but once warm, it's just fine. Also, it seals up well enough to keep even a heavy rain out, and with the windows removed, it makes a decent safari top.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #7 of 13 Old 04-09-2011, 03:38 PM
timatoe
timatoe's Avatar
I've got a Bestop Sunrider and it works absolutely fine with my full doors.
timatoe is offline
post #8 of 13 Old 04-09-2011, 05:32 PM
MDWG
2009 JK Wrangler
I got full doors with the hard/soft top combo so I ordered the bikini BC I preferred that , how well did your bikini top seal with the full doors?
[_|_,[__],
[--|_|- OlllllO-
( )_) ( )_)-)_)
MDWG is offline
post #9 of 13 Old 04-09-2011, 05:58 PM
superj
none of our bikini tops ever worked with full doors. my 87 or my wife's 93. they both have gaps of about an inch across the top of the door
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #10 of 13 Old 04-09-2011, 06:52 PM
MDWG
2009 JK Wrangler
Well this should be fun in these upcoming summer months
Edit: though this IS a good excuse to get some half doors lol
[_|_,[__],
[--|_|- OlllllO-
( )_) ( )_)-)_)
MDWG is offline
post #11 of 13 Old 08-18-2011, 09:50 PM
easyxbox
try jeepsareus.com idk where these people hide at but the did make the jeep hardware for both jeep doors my best answer would be to google it or ebay it you'll find somethin
easyxbox is offline
post #12 of 13 Old 08-18-2011, 11:40 PM
dodger889
supertop, or sunrider top both work well with full doors. OME tops will work but you will have a large space in the corners of the door.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #13 of 13 Old 08-18-2011, 11:44 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
X2
Supertop and Sunrider have an option for to purchase for Jeeps with Full Steel Doors
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
Half doors to full steel doors - '94 body, '88 doors xponce YJ Wrangler Technical Forum 8 02-20-2010 04:29 PM
switching out full steel doors for soft doors. monkeychrist TJ Wrangler Technical Forum 8 07-19-2007 11:41 PM
full steel vs full soft doors kennydenney TJ Wrangler Technical Forum 15 08-29-2006 12:41 AM
Filling softtop gap between full doors wilesn1 YJ Wrangler Technical Forum 2 05-22-2004 01:55 PM
new soft top hardware for full doors renegade0351 YJ Wrangler Technical Forum 0 06-02-2002 12:55 PM
