Soften up the ride a bit? - JeepForum.com
post #1 of 12 Old 09-15-2003, 10:27 AM Thread Starter
nosajmc
I have a 92, with skyjacker 2.5" and Kuhmo 31x10.50x15's.....
both tires and lift are newly installed
This is my DD that makes it off road maybe 1 or 2 times a month....the ride is just a bit rough...i mean its a lifted jeep and I expect it to be stiff, but I was wondering if there is anything I can do to soften the ride up some...
White 02' GMC Sierra 2500HD
8.1L w/ Allison 5spd
nosajmc is offline
post #2 of 12 Old 09-15-2003, 10:39 AM
TellyDSP
Poland and PPV!!!!
Depends how newly installed it is. I know many lifts can be stiff for about a week or two before they soften up. Could also be affected by the type of shocks you put on.
-Craig-
95 Rio Grande
07 Ram 1500
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline
post #3 of 12 Old 09-15-2003, 10:41 AM
D4FS4
D4FS4's Avatar
How about sitting on one of those?
D4FS4
1994 YJ
D4FS4 is offline
post #4 of 12 Old 09-15-2003, 11:17 AM
Devious
Hobo Shanker
Devious's Avatar
2014 JK Wrangler
Or trade in the Jeep on a Liberty
Life is tough enough already, but it's even tougher when you're stupid
Devious is offline
post #5 of 12 Old 09-15-2003, 11:50 AM Thread Starter
nosajmc
Alrighty there smart *****...have a laugh at my expense...tis ok by me
If it wasn't for the comments(*****ing) that my wife does, I wouldn't have mentioned it.
as for the relevant questions..
These rear and front are the shocks I have.
and the lift is very new....less than a week old....in any case nothing will be done for another 3-4 weeks
nosajmc is offline
post #6 of 12 Old 09-15-2003, 11:52 AM
D4FS4
D4FS4's Avatar
For some reasons I had bet the discomfort comments were coming from a wife
D4FS4
1994 YJ
D4FS4 is offline
post #7 of 12 Old 09-15-2003, 11:59 AM Thread Starter
nosajmc
She's just pissed that i sold our comfort laden, hopelessly inadequate Isuzu Trooper....
Not that its a bad vechicle by any means....Hell I owe my interest in off roading to it....But it is certainly no where near as capable as a the new ride
nosajmc is offline
post #8 of 12 Old 09-15-2003, 01:13 PM
Smoke
Smoke's Avatar
I only run about 25lbs of air in my tires. Helps a lot. Hydraulic shocks instead of gas too.
Smoke is offline
post #9 of 12 Old 09-15-2003, 01:20 PM Thread Starter
nosajmc
Shocks are Skyjacker Hydros...7056 up front and 7051 in the rear
Tires are at 28lbs.
Maybe its just the "newness" of the springs...
nosajmc is offline
post #10 of 12 Old 09-15-2003, 01:27 PM
EMT Jeeper
EMT Jeeper's Avatar
Tires are at 28lbs.
Check your shackle bolts. Put a wrench on the bolt head (not the nut) and try to spin it. You should be able to turn the wrench fairly easily (shouldn't spin freely but you should be able to turn it). If the shackle bolts are too tight, the spring has to work even harder to flatten out when you hit a bump. I put a nice coat of grease on the bushings where they contact the shackle. Other than that I would say take it out and flex it. Gotta break the springs in sooner or later.
1993 YJ
4" Skyjacker lift, Revolvers in the rear
32" Super Swamer TSL's
DANA 44 front, 9" rear, and Chevy 350 waiting to go in on 36" TSL's
EMT Jeeper is offline
post #11 of 12 Old 09-15-2003, 01:34 PM Thread Starter
nosajmc
i will double check that...
i know they are greased, as i replaced the bushing when the lift went on, but i do not know how tight they are....i might have overmuscled it a bit
nosajmc is offline
post #12 of 12 Old 09-15-2003, 01:39 PM
Justhere
antiseize is what to put on them not grease it does not come off
Justhere is offline
any way to soften up throttle? KI4KWF TJ Wrangler Technical Forum 12 07-29-2007 09:49 PM
best way to soften up ride?? bombadillo YJ Wrangler Technical Forum 15 06-29-2006 01:46 PM
Will new front control arms soften my ride? Roothog TJ Wrangler Technical Forum 13 04-21-2006 09:51 AM
How to soften ride?? itsajeepthing17 YJ Wrangler Technical Forum 1 12-17-2005 12:44 AM
How to soften ride?? itsajeepthing17 YJ Wrangler Technical Forum 20 12-15-2005 12:09 PM
