soft upper question - JeepForum.com
post #1 of 4 Old 01-20-2010, 03:57 PM Thread Starter
jeepnphreak
1989 XJ Cherokee
soft upper question
I found a set of soft upper doors WITH rounded rear corners for a yj...
will they work with a hard top?
My hard top has the rounded rear corners, so it looks like it may fit...
I gues the second question would be why/why not? I have not yet found a solid awnser as to how upper doors fit with a hard top that are not the sliders (wich I dont want)
1989 XJ, 5spd, np231 with bjconversion SYE , re3.5, 33x12.5r15 BFgoodrich ATS, D30 F, Dana 44 from 87 with 4.56s, Custom front bumper.
94 yj: stock everything and 4 angry squarrels under the hood.
jeepnphreak is offline
post #2 of 4 Old 01-20-2010, 06:28 PM
Blazin Den
you can make TJ uppers work with the hardtop.
http://www.jeepforum.com/forum/f12/h...ardtop-939892/
and use Length Envy page to see where to cut the back pin
http://www.jeepforum.com/forum/f12/l...0/index20.html
95 White YJ 2.5L/AX-5 Stock on 31s. Ground Pounder Fab (BESRK) Front Bumper, Herculined Interior, Windshield/Front Bumper Mounted Lights, Uniden PRO 520XL Cb,Hidden Hitch Trailer Hitch, Bestop Supertop, Modified CJ7 Hardtop and CJ7 Twist Handle Full Doors (winter)
Blazin Den is offline
post #3 of 4 Old 01-20-2010, 07:29 PM Thread Starter
jeepnphreak
1989 XJ Cherokee
So Iam I seeing that right?
You just cut off the rear pin at a 90* angle to the end that mount in the hole. mount it in the rear hole, line up the soft upper and reweld the rear pin in the new location? really that simple or Iam I missing somthing?
post #4 of 4 Old 01-21-2010, 08:40 AM Thread Starter
jeepnphreak
1989 XJ Cherokee
Bump for comformation of my last post please. I would hate to drop a few $ of doors and screw them up.
dead horse question, upper sliders-soft top? 92fiddler YJ Wrangler Technical Forum 9 02-25-2009 11:21 PM
Soft door upper question jeepwrnglr92 TJ Wrangler Technical Forum 5 09-10-2008 08:54 AM
Soft upper door question Chris_Ryan TJ Wrangler Technical Forum 7 02-20-2007 04:05 PM
soft upper door skin question 89islanderchaz YJ Wrangler Technical Forum 5 01-11-2006 08:23 PM
Soft upper door install question natef26 TJ Wrangler Technical Forum 1 04-15-2004 01:59 PM
