Soft top part-What is it? - JeepForum.com
post #1 of 7 Old 09-14-2011, 06:50 PM Thread Starter
lah2420
Sorry. No picture, but maybe my explanation will help you see it. Bought my little jeep last month with a Safari top and a soft top. I put the soft top on and have 2 straps I don't know where to put. They are at the back window. Both are about 6 to 8 inches long. They have a rectangular plastic or rubber piece at the end of them. They are somewhat elastic. Where do they go? I know about the straps to roll the window up. I'm using those. But these other 2 just hang there.
lah2420 is offline
post #2 of 7 Old 09-14-2011, 07:02 PM
dadstoy
They are used to "tie" the frame down when you take the top off. The strap wraps around the folded frame and the plastic thingy tucks into the frame rail...........
dadstoy is offline
post #3 of 7 Old 09-14-2011, 07:09 PM Thread Starter
lah2420
Makes sense. I thought I was missing something when I put the top on. Thanks. I was afraid I was going to freeze to death. Temperatures are dropping into the 70s at night here in SW Arkansas. And only in the mid 90s during the day for the weekend. After 106 yesterday, I might have needed a coat to run with the safari top. My 87 had a hard top. So much easier to put on and take off.
lah2420 is offline
post #4 of 7 Old 09-14-2011, 07:22 PM
ejeeperguy
1982 CJ7
You guys in Ark. are such panseys. Come up to New england and play. We don't even put socks on if there isn't 4 inches of snow on the ground.
Happy Wheeling!!!
ejeeperguy is offline
post #5 of 7 Old 09-14-2011, 07:28 PM Thread Starter
lah2420
I grew up in Illinois. I prefer being a pansy to the snow. They roll up the sidewalks and close everything but where I work when just the forecast calls for snow flurries here.
lah2420 is offline
post #6 of 7 Old 09-14-2011, 07:40 PM
ejeeperguy
1982 CJ7
Okay I give you street cred for Ill. I was there at Chanut A.F.B. in Jan. cold is cold.
post #7 of 7 Old 09-15-2011, 01:21 AM
tankinyj
x2, this would be those straps. Or your talking about the straps that hang from the rear window? those are used to 'stow the rear window when you have your top up and the windows out. instead of removing the rear window you can just roll it up
edit: temps dropping to 70 and you freeze? jeeze, i think you would hate it here in NY in the winter then... keep a hoodie in the rig
tankinyj is offline
Soft top part name.... duckman1 TJ Wrangler Technical Forum 4 05-18-2011 01:31 PM
Soft top part help Ksit YJ Wrangler Technical Forum 0 09-16-2010 05:32 PM
name this soft top part best top bword YJ Wrangler Technical Forum 4 05-27-2010 08:34 AM
soft top part id jeepn00tj TJ Wrangler Technical Forum 6 02-03-2009 03:32 PM
what is this soft top part for? Geeps TJ Wrangler Technical Forum 14 10-19-2005 02:35 PM
