Soft Top - JeepForum.com
post #1 of 3 Old 06-20-2001, 04:39 PM Thread Starter
Tsolkas
Soft Top
I'm in the process of buying a 1992 Wrangler. I have an old 1991 Wrangler factory soft top. Does anyone know if it will fit on the 1992?
Tsolkas is offline
post #2 of 3 Old 06-21-2001, 01:13 PM
JeepinGirlinFl
JeepinGirlinFl's Avatar
Well, I am new to Jeeps - but Quadratic is great at helping with tech questions. YOu may be able to call them and get an answer asap. Try Quadratic.com
Hope that helps a lil
87 Wrangler
4.2L I6
2.5 Skyjacker Lift, chrome grill, steel step bumperettes, new bestop trailmax front seats, K&N, Por15'd frame, Por15'd cab with por15 topcoat....whatever is nasty is being removed and restored!
JeepinGirlinFl is offline
post #3 of 3 Old 06-21-2001, 06:26 PM
Tonka
2015 JK Wrangler
only if you use the same door style as the first jeep.(square or round cornerson top rear edge of door)
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline
Soft top question regarding straps coming off the soft top bars. newjeepowner05 JK Wrangler Technical Forum 12 12-30-2013 06:49 PM
Bestop makes 2 piece soft doors which match with Factory soft top? AROSETO TJ Wrangler Technical Forum 9 02-23-2010 11:41 AM
Need soft top - Whats the scoop on Viking soft tops? Q-01 TJ Wrangler Technical Forum 3 01-11-2008 07:36 AM
Soft top issue problem solver, must read if you have a YJ soft top marvin51796 YJ Wrangler Technical Forum 9 03-04-2005 12:50 PM
re: do soft top windows from older best top soft tops fit 03 wrangler?? skaboyy TJ Wrangler Technical Forum 3 06-12-2004 01:59 PM
