Soft clutch pedal. - JeepForum.com
post #1 of 5 Old 04-04-2013, 04:36 AM Thread Starter
grizzlycb
Soft clutch pedal.
So I just got a brand new tranny and clutch pressure plate slave cylinder put in along with getting my flywheel resurfaced. (92 2.5 yj btw)Now my clutch pedal is softer than ever. I had a professional mechanic who happens to be my uncle put it all in for me since I work night shift and really needed my dd back. I've read it is air in the hoses. How do I go about fixing that on a yj?
grizzlycb is offline
post #2 of 5 Old 04-04-2013, 06:24 AM
EABiker
You need to bleed the system. The basics are to put a clear hose over the slave bleeder fitting, (I like to break the bleeder loose before putting the hose on it). Remove the master cap and fill it with fluid. Have a helper depress and hold the pedal to the floor, (say, "down"), loosen the bleeder; some fluid will enter the hose; watch for bubbles. Tighten the bleeder, (not all the way, just till snug), and say "Up", your helper will let off the pedal. Repeat this process until no more bubbles appear, or the pedal is firm, then fully tighten bleeder valve and fill/cap the master.
BIG NOTE HERE!!!!
Check the fluid level in the master EVERY 3 PUMPS! you will need to fill the master to the top after 3 pumps; if you go to 4, you may suck in air and be worse off than when you started!
EABiker is offline
post #3 of 5 Old 04-04-2013, 09:42 AM
Flajeeper1
1987 YJ Wrangler
Correct, just a couple of suggestions:
[QUOTE=EABiker;15244621]You need to bleed the system. The basics are to put a clear hose over the slave bleeder fitting, (I like to break the bleeder loose before putting the hose on it). Remove the master cap and fill it with fluid. Then replace the cap.Have a helper depress and hold the pedal to the floor and hold the pedal down until you say "Up", (say, "down"), loosen the bleeder; some fluid will enter the hose; watch for bubbles. Tighten the bleeder, (not all the way, just till snug), and say "Up", your helper will let off the pedal. Have the helper pump the pedal until it becomes firm before you bleed again. Repeat this process until no more bubbles appear, or the pedal is firm, then fully tighten bleeder valve and fill/cap the master.
Flajeeper1 is offline
post #4 of 5 Old 04-06-2013, 03:15 AM Thread Starter
grizzlycb
Sounds like something I can manage I guess I'll do that when I go to put my lift kit on. Another question might be kinda a newbie question but does it hurt to drive it with air in hose?
post #5 of 5 Old 04-06-2013, 03:20 AM
Captainak
1982 CJ7
http://youtu.be/vKV8a0QL5uk
https://plus.google.com/photos/11645...83655447386049 or
1982 CJ7, AMC 401, Dana 60 & 14 Bolt
http://jeepspace.jeepforum.com/Captainak
https://plus.google.com/photos/116451153412037001676/albums/5857883655447386049
Captainak is offline
