soa vs re 4.5 extreme duty - JeepForum.com
post #1 of 5 Old 10-18-2001, 08:05 PM Thread Starter
JYRUS
can someone give me the pros and cons of both. how much difference is there in flex. thanks for the help.
JYRUS is offline
post #2 of 5 Old 10-18-2001, 08:08 PM
Brendan
The SOA has a better on-road ride, and much better flex. The RE kit will cost you 1000 to purchase, but nothing to install. The SOA is much harder to install, but in the long run it is worth it.
Duvie
95 YJ 2.5L 5 Speed
Fightin a war against Florida Rust!
Brendan is offline
post #3 of 5 Old 10-18-2001, 09:10 PM
RodeoRob
RodeoRob's Avatar
I helped put the RE 4.5" kit (non extreme duty) on my friends YJ. It rides considerably rougher and flexs decent. In retrospect, I'd rather have done a SOA just for the ride quality aspect.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
post #4 of 5 Old 10-19-2001, 09:50 AM
ralstonm
remember that the Extreme and the regular RE lift use totally different springs. The regular one just has Pro comp 4", which are notoriously stiff. The Extreme 4.5 is supposed to be much better.
The SOA, like everybody has said, flexes and rides better, but is a ton tougher to put together and get running right. It complicates driveline, steering, brakeline, and possibly axle wrap issues.
Try a search of the archives on this and I bet there is more info on this dilemma.
Matt
'95 YJ about to start looking a little bigger
ralstonm is offline
post #5 of 5 Old 10-19-2001, 08:02 PM
bob91yj
Without regard to which rides better- SOA is typically going to be a custom job, and it may be difficult to find a shop willing to do the work if you don't plan on doing it yourself. Welding and parts fabrication are usually required. I also understand there are some states in which the SOA is illegal. The RE 4.5" Extreme Duty is bolt on, and can be done in a driveway with hand tools and a floor jack. It can be installed in a weekend, including the SYE.
That being said, I love my SOA and wouldn't really consider going back to SUA under any cicumstances. I helped install an RE 4.5ED on a buddies Jeep and have since wheeled with him. I'm pretty impressed with the flex of the RE, and my buddy is very happy with the ride quality on the highway.
I think either would be a good choice. Big help, huh.
Bob
91YJ Sahara, SOA, 4.88's, 35's, Locked
bob91yj is offline
RE 4.5 sf or 5.5 Extreme duty TJ Flexer TJ Wrangler Technical Forum 12 02-17-2008 10:24 AM
RE Extreme Duty Install, Is this OK? ptowntj TJ Wrangler Technical Forum 7 06-16-2007 11:06 AM
re 4.5 extreme duty blb_yj YJ Wrangler Technical Forum 3 07-08-2006 10:02 AM
RE 4.5 extreme duty vs standard Damage_ctrl YJ Wrangler Technical Forum 28 05-17-2006 11:02 PM
RE extreme duty vs. standard blakkbelt YJ Wrangler Technical Forum 4 04-23-2004 01:05 PM
