SOA and traction bar question.. - JeepForum.com
post #1 of 15 Old 08-08-2011, 07:28 AM Thread Starter
Skooter
I see everyone who does SOA say you must have a traction bar system. I am curious why they have to have one after SOA? There are a few million vehicles out there with leaf springs over the axle with no trac system and they do just fine. What makes a YJ leaf and axle so different?
2005 Ram 3500 Qcab Cummins 4X4
89 YJ 4cyl/5spd, 3" BL, 2" shackle, 33 TSL's
73 Challenger 340 Rallye
Skooter is offline
post #2 of 15 Old 08-08-2011, 07:56 AM
pasinbuy
The new pinion angle after you do a SOA. Makes axle wrap too easy.
pasinbuy is offline
post #3 of 15 Old 08-08-2011, 10:00 AM
E_ROCK
The jeep draintrain length is too short. You quickly exceed the max u-joint angle and pop them. We also 4wheel and a bunch of trucks just see the street. Take some cues from Formula Toy builds. F-toy have to be leaf sprung to compete. They also put in anti-wrap bars.
From personal experence...Your anti-wrap bar design can also cause rear hop. Make sure you make it as long in length as possible. I had a shorter one and had bad rear hop climbing rocks. I stretched my rear wheel base 4 inches and lengthen my anti-wrap bar like ~6"-8" inches. No more rear hop and the tires hook up better.
Garage Monkey, Wheeling Junkie
E_ROCK is offline
post #4 of 15 Old 08-08-2011, 12:08 PM
leadsled01
YJ springs are soft , when you go SOA its too much strain and you will get alot of wrap which will eat rear drive shafts/ujoints. I went SUA rear and SOA front and love this set up.
leadsled01 is offline
post #5 of 15 Old 08-13-2011, 12:55 PM Thread Starter
Skooter
Now this I'll buy, I just cant believe YJ springs are all that soft. My YJ has more leafs than my Dakota and the Dak hauls 2000lbs around all day without a trac aid.
What engine/power do you have? I guess Im safe in assuming a 300hp 340 is going to compound my problem in that repect?
Btw.. thanks for the input from everyone.
Skooter is offline
post #6 of 15 Old 08-13-2011, 02:07 PM
yj87ben
I have the SOA suspension. Started with Rancho 1.5" lift springs without a traction device. See picture. Destroyed the springs. Replaced with factory five leaf, and did the same thing. Built and installed a traction bar, no more problems. And you know how sometimes YJs squat in the rear under acceleration, gone.
yj87ben is offline
post #7 of 15 Old 08-13-2011, 03:34 PM
timatoe
timatoe's Avatar
Has nothing to do with the "softness" of the springs. It's pretty well proven that it's needed, seems like a silly waste to do all the work of going SOA and not complete the job.
timatoe is online now
post #8 of 15 Old 08-13-2011, 06:50 PM
E_ROCK
I have the stock 4.0. HP compounds the problem. Here is the hopping that I was getting,
http://erock.rockfrogs.org/Video/Indy_exit.wmv
It is gone now! I stretched the wheel base, added wheel base length, and run ford ranger springs.
E_ROCK is offline
post #9 of 15 Old 08-13-2011, 08:55 PM Thread Starter
Skooter
What in the world are you using for a power plant?? I havent seen that done to leafs since my 440 Cuda on N2O!!
I guess I just cant wrap my head around the geometry of the YJ suspension and yes.. I will be building a traction device to keep that from happening and thanks for the length and spring brand advice.
Skooter is offline
post #10 of 15 Old 08-13-2011, 08:59 PM Thread Starter
Skooter
Thanks again for your advice E Rock.
Skooter is offline
post #11 of 15 Old 08-13-2011, 11:42 PM
TSEJEEPERS
I think it all depends on the vehicle.
I had severe axle wrap. 4.0L SOA with Rubicon Express SOA springs.
I could not keep a rear driveshaft under it so save my life.
Some freinds I wheel with have a YJ SOA 2 inch lift springs 4 cylinder,
another has a CJ SOA XJ springs in front reverse shackle, no name springs on rear, Ford 304.
The last has stock CJ springs SOA with a AMC fuel injected 360.
None of them have have axle wrap.
Not sure why?
I will say a traction bar is alot cheaper to build and install than replacing driveshafts.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #12 of 15 Old 08-14-2011, 05:28 PM
SkyJumper
Well one of your major issues with that leaf warped is not necessarily from torgue wrap, but that of you running a too large/long of a perch. That perch is way too long and flattens out the spring too much at center mount contact. You should be using a smaller perch IMHO.
SkyJumper is offline
post #13 of 15 Old 08-20-2011, 02:20 PM
yj87ben
2.5L 4cyl., AX5, NP231 to D30/35 4.56s, w/ARBs.
yj87ben is offline
post #14 of 15 Old 08-20-2011, 02:32 PM
jeepinmichguy_
Hey, you can find my info now. Just click on my jeeps in my sig (I figured I'd help you out).
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?
Originally Posted by JeepForum123 View Post
you all have nice rigs, stop being f****** a**holes.
jeepinmichguy_ is offline
post #15 of 15 Old 08-24-2011, 09:29 PM
yj87ben
You could be right. The perches came from Rocky Road Outfitters in their piece of crap Bolt-on SOA kit. Needless to say the perches(rear)aren't bolted-on. The 8.8 will be in this month, and I'm going with much shorter perches from Cut throat 4X4.
yj87ben is offline
TJ Traction Question leeave96 TJ Wrangler Technical Forum 18 08-28-2009 05:28 PM
Yet another SOA traction bar question..... LilViper95 YJ Wrangler Technical Forum 7 04-12-2008 05:15 AM
Traction Control Question Dmwil JK Wrangler Technical Forum 4 08-27-2007 11:10 PM
Traction Bar Question chuckyj95 YJ Wrangler Technical Forum 3 09-04-2006 07:17 AM
question about traction albertjeepster TJ Wrangler Technical Forum 13 01-22-2004 06:29 PM
