Soa Tire Alignment - JeepForum.com
post #1 of 5 Old 05-19-2006, 01:16 PM Thread Starter
HARLEYX2
1987 YJ Wrangler
Soa Tire Alignment
Can A Tire Store Still Align The Front End Of A Yj With A Soa? Do They Do It With The Same Specs As Sua?
HARLEYX2 is offline
post #2 of 5 Old 05-19-2006, 01:21 PM
Bob_R
A alignment can be made as usual.
GROWING OLDER IS MANDATORY, GROWING UP IS OPTIONAL TREAD LIGHTLY
Bob_R is offline
post #3 of 5 Old 05-19-2006, 01:53 PM
jeffy
jeffy's Avatar
All an alignment shop can do is adjust the 'toe' and straighten the steering wheel. If you have not removed the drag-link the the toe should be fine. If you've clocked the pinion or added lift shackles, that will change the caster adjustment and the only way to correct would be to shim the housing. Caster is set by the inner knuckles (C's).
And yes, they would try to set it back to stock (sua) specs.
*** www.4BangerJP.com ***
jeffy is offline
post #4 of 5 Old 05-19-2006, 03:06 PM Thread Starter
HARLEYX2
1987 YJ Wrangler
Actually Caster And Camber Can Be Adjusted.
HARLEYX2 is offline
post #5 of 5 Old 05-19-2006, 08:44 PM
BackRoadJPin
1995 Wrangler
BackRoadJPin's Avatar
the alignment shop should be able to adjust it just like normal.
from what I can tell you are looking at going SOA in the near future or you are at least weighing your options.
you will at the least need to do cross over steering with a flat top knuckle, unless you use the stock springs, I have read.
I used 2" lift springs on mine and swapped in a front 44 while I was at it and went full high steer on L/R flat top knuckles.
Back Road Jeepin
BackRoadJPin is offline
rear tire alignment vailhunter TJ Wrangler Technical Forum 4 12-28-2007 10:24 AM
Tire (sidewall rip) and Alignment question ramrat TJ Wrangler Technical Forum 3 08-14-2007 09:36 PM
Tire wear / alignment question HMTwin TJ Wrangler Technical Forum 4 06-12-2006 08:23 AM
tire alignment scs210 TJ Wrangler Technical Forum 5 07-03-2005 07:11 PM
tire alignment??????? tcross34 TJ Wrangler Technical Forum 5 10-26-2001 09:40 AM
