soa with suspension and shackle lift - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > soa with suspension and shackle lift
GenRight Offroad at CCOR! 706-207-4140Ring & Pinion's, Lockers, 4340 Axles, Install Kits, BaWarn, Smitybilt, Engo, Rugged Ridge Winches at CCOR
Unread 08-19-2009, 10:07 PM   #1
joeyrossmiller
this seems kind of ridiculous to me. and even kind of pointless... maybe. but for the sake of discussion. what do you think of doing the soa conversion along with already having a 4 inch rough country lift and an 1 1/4 inch shackle lift. what would be the obstacles? the necessities for doing this? what kind of other upgrates would be involved along with some kind of cost. has anyone done this? what would be the purpose?
just kind of thought it'd be an interesting topic, im not actually considering doing it, im not in the position to do this now as my heep isnt even running, and i dont know why i would need it
94 sahara, 4" rough country, 1 1/4" home made shackles all around, 33" trxus m/t, home made cai, hesco tbs, flowmaster super 40, no track or sway bars, 4.0 h/o, home made rocker guards, re-routed the trans vent
GIT R DID, GIT R DONE
joeyrossmiller is offline   Reply With Quote
Unread 08-19-2009, 10:16 PM   #2
antec
you know that 10 and 3/4" lift right???
antec is offline   Reply With Quote
Unread 08-19-2009, 11:49 PM   #3
joeyrossmiller
i read that soa could get you 5-7 inches so it could be 10 1/4 to 12 1/4. that'd be interesting. also with no sway or trac bars
Unread 08-19-2009, 11:54 PM   #4
antec
more then interesting.
your cog with be 10" higher then you add about 5-9" more b/c the tires.
you will need to go full width and strech it then i still dont think it would be good for anything but a mall crawler.
Unread 08-20-2009, 01:18 AM   #5
gearhead1985
umm i think 44's would fit nicely under that setup do it tell us how it works
i want to put a pic here but the computer won't let me so here is the link
[url]http://i641.photobucket.com/albums/u...85/dnsjeep.jpg[/url]
gearhead1985 is offline   Reply With Quote
Unread 08-20-2009, 01:20 AM   #6
ImpactFabWorks
Personally I think it's too high. But, that's for me. A stretch and full width would be a must. Otherwise it would just scary
1990 YJ = The Toy/ My Daily Driver
1996 XJ= Wifes Daily Driver
www.Impact-FabWorks.com
Impact-FabWorks Facebook
Please fill out your profile, It helps us help you!!!
ImpactFabWorks is offline   Reply With Quote
Unread 08-20-2009, 02:12 PM   #7
joeyrossmiller
i think it'd deffinately be a mall crawler. but i dont think i'd do it. just seein what people thought. i'd like to see it though. a good build thread with all of this
Unread 08-20-2009, 02:13 PM   #8
joeyrossmiller
oh and what does full width mean? i know stretching it is stretching the frame length wise
Unread 08-20-2009, 02:30 PM   #9
Joe Dillard
Electric Chair Operator
Full width = the axles are swapped in from a fullsized truck, which are much wider.
Joe Dillard is offline   Reply With Quote
Unread 08-20-2009, 02:43 PM   #10
joeyrossmiller
thats kinda what i figured
Unread 08-20-2009, 02:44 PM   #11
Joe Dillard
Not necessarily.
Yes, you *can* stretch the frame & move the axle mounting points further away, but there's more ways to skin that cat.
You can also use springs which have the centerpin offset - which can stretch the wheelbase.
You can also use spring perches that have multiple centerpin mounting holes in them as well (these perches are usually longer than normal). You can stretch the wheelbase a couple inches using them as well, especially if you do it at both ends.
You can also open up a whole can of worms by doing any of these options.
EG: Now the gas tank can come in contact with the rear axle unless this area is addressed in the overall game plan. Lengthening the fuel lines etc are sometimes needed too - especially if the rear frame is extended in the mix of things.
I have helped do all of these options and combo's of them & then others as well. It can get tricky quick.
Unread 08-20-2009, 05:05 PM   #12
joeyrossmiller
i know any lift can be tricky. even a shackle lift (i know from experience). but combining all of these would almost be a daunting task. whats the biggest lift you guys have seen? pictures?
Unread 08-20-2009, 05:08 PM   #13
1998zj
I have seen some scary builds with a couple feet of lift.
"Our lady of blessed acceleration don't fail me now"
1998zj is offline   Reply With Quote
Unread 08-20-2009, 05:28 PM   #14
Joe Dillard
I have as well, and like you mentioned, they are often booty fabbed & end up being a big POS & barely driveable. Often being a big waist & poorly put together due to lack of understanding and poor approach.
Unread 08-20-2009, 09:54 PM   #15
joeyrossmiller
on a jeep?
