SOA to SUA??? - JeepForum.com
post #1 of 33 Old 10-30-2011, 10:21 AM Thread Starter
worleysc
SOA to SUA???
I purchased an 89 YJ with a spring over conversion and worn out 3.5" Superlift springs that had leafs removed (2 from the front and 1 from the rear), great off road, not so great on the road. Decided to make it safer since my son (his first vehicle) will drive it most of the time. So I purchased the only springs my local 4wp center had in stock for a YJ. 4" procomp. Pretty close to what was on it, so why not. Bolted right up, no problems, except now it was a little too high. Should have planned better, I know. It's all good, spring under will give a solid 4" lift and I can still run the new 35 inch tires that came on the jeep. The problem I have now is that the axles are not centered in the wheel well, front or rear. WTH? The pins are located in the center of the spring pack and we measured that before we started tearing it down. I still need to relocate the spring perches for pinion angle, and yes the new cv shaft is probably too long now, and Im not happy about that, but I should have planned better, I know. Any advice or explanation would be appreciated. Thanks.
worleysc is offline
post #2 of 33 Old 10-30-2011, 10:29 AM
Ripper3494
nothin really you got it covered, relocate perches, set pinion angle, modify driveshaft, only like 80 bucks. another option that most guys do is keep the soa with the stock springs thatll give you a nicer ride and 5.5in of lift. using lift springs with soa is an accident waiting to happen most of the time
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #3 of 33 Old 10-31-2011, 05:33 PM Thread Starter
worleysc
So today I was piddlin around in the shop, cleaning and thinking. Scary stuff. As I prepare to yank out the rear axle housing as to weld up new perches, I hit a road block. An old 9inch (3:00-1 ratio) from one of my Galaxie projects is right in the way. Tape measure in hand, I think what the heck. Guess what, it measures out to 60.75 exactly, 5x4.5 bolt pattern, yoke to CL of axle is the same, cool. Tear down begins.
worleysc is offline
post #4 of 33 Old 11-01-2011, 11:07 AM
1tuffyj
That's not gonna be the same shaft spline count as trucks. Ill guess 28 instead of 31. Just fyi
the pressure makes us stronger, the struggle makes us hunger, the hard lesssons make the difference, and the difference makes it worth it.
1tuffyj is offline
post #5 of 33 Old 11-01-2011, 06:32 PM
burnout189
good stuff on the 9"
SOA on 4" springs is going to give you a BIG jeep. That thing is going to be dangerous on the street unless you spend some bucko's on the steering and driveshafts.
I would suggest going back to sua on the 4" springs if you dont want to mess with the steering, etc.
EDIT: I actually read your post this time, and realized that you already decided to go SUA. Disregard this statement ^
BARNHART'S AUTO REPAIR
burnout189 is offline
post #6 of 33 Old 11-01-2011, 06:57 PM
Apollo12227
If you are going to install a ford 9" in your jeep you will need to upgrade to 31 spline shafts. The 28 spline shafts WILL FAIL with larger tires and moderate abuse. I have a ford 9" in my jeep, I'm 100% happy with it. I have 4.56 gears and a Detroit locker. You need to invest in new shafts if your going to go for it.
Apollo12227 is offline
post #7 of 33 Old 11-01-2011, 07:08 PM
youngjeepr
I would order a set of stock replacement springs and stay SOA
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
post #8 of 33 Old 11-02-2011, 06:22 AM Thread Starter
worleysc
Thanks for all the replies. For now I'm staying with the 4" sua, I like the way it rides on asphalt.
As far as the 9" goes, 28 spline is correct. But it is a direct bolt in minus the perches and shock mounts, which I have to do fab work on either axle.
worleysc is offline
post #9 of 33 Old 11-02-2011, 04:10 PM
HARLEYX2
1987 YJ Wrangler
Its not a direct bolt in if it doesnt have the same gear ratio as the front. 3.07 gears. 35s and those gears and it will be a turd. Also unless you have a body lift 35s wont fit with a SUA 4 inch lift.
HARLEYX2 is offline
post #10 of 33 Old 11-02-2011, 04:31 PM
plmqazed
ripper basically just said it all
plmqazed is offline
post #11 of 33 Old 11-02-2011, 05:22 PM
giggityjeeper
meh I run SOA and 3.5 springs and 5/8 shackles, no sways and no trac bars, its quite manageble on and off road actually... drive it accordingly... its not a race car thats for sure
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #12 of 33 Old 11-03-2011, 01:30 AM
tankinyj
yes the spline count on a 9" out of a car is 28 spline. UNLESS it is a 9" out of a big block or hi-po mustang/torino (boss 302, boss429, boss351, 428 SCJ, etc then you will have the 31 spline axles with the larger bearings
2012 JK, 44s locked on 4.56s, 4:1, 3" on clayton arms, 37" PBRs
Crush Orange Jeep Member #55
tankinyj is offline
post #13 of 33 Old 11-04-2011, 08:53 PM Thread Starter
worleysc
Well, gears are inevitable anyways. I was merely referring to the dimensions. 35s will fit, that part is done already, more than enough clearance. As far as 9" big or small bearing, 31-28, doesn't matter, still better than a stock Dana. Thanks for all that helped, not so much to those that just try to squash.
worleysc is offline
post #14 of 33 Old 11-04-2011, 09:22 PM
HARLEYX2
1987 YJ Wrangler
So you are running 35 inch tires SUA with a 4 inch spring and no body lift or cut fenders?
HARLEYX2 is offline
post #15 of 33 Old 11-05-2011, 02:09 AM
durrster1128
thats what i was running on my jeep before the rebuild. they actually fit nicely.
durrster1128 is offline
