SOA steering bracket - JeepForum.com
post #1 of 13 Old 04-22-2010, 09:27 AM Thread Starter
nj95yj
Dana 30 High Steer Knuckle for Jeep Wrangler (87-06) Blue Torch FabWorks, Inc.
Discuss..... Pros????Cons??
One lovely blue 97' with 33's and 4 pissed off hamsters under the hood
nj95yj is offline
post #2 of 13 Old 04-22-2010, 10:55 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
For starters, the name of the part is incorrect IMO.
It is NOT a "high steer" adapter, it is a "crossover Steering" adapter.
"High Steer" IMO puts ALL of the steering up high & out of harm's way. With this part, the tie rod has no more protection than stock. It only serves to address the drag link angle, which can be done cheaper with a dropped pitman arm.
I give it a "Thumbs Down"
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 13 Old 04-22-2010, 11:36 AM
timatoe
timatoe's Avatar
There's a little bit of info in here.... http://www.jeepforum.com/forum/f12/b...racket-943642/
timatoe is offline
post #4 of 13 Old 04-22-2010, 11:48 AM
fratis
fratis's Avatar
not with a soa configuration. a drop pitman arm alone is useless (never even had one on my soa) as the leafspring pack is literally in the way of the drag link. this bracket was designed at a time when there were little options for proper steering on a soa. outside of a knuckle and hub swap the teraflex knuckle was the only option, but it was expensive and the casting had the draglink arm too long. this bracket along with some other products now on the market, that are "cross-over" units, are good options for those going soa but not ready to swap front axle assemblies. much better then a drop pitman arm and a "z" bent drag link.
fratis is offline
post #5 of 13 Old 04-22-2010, 01:07 PM Thread Starter
nj95yj
does anyone have one? can it handle a beating?
nj95yj is offline
post #6 of 13 Old 04-22-2010, 02:12 PM
notmyj
I have it. I just installed it on my SOA build. I havnt had a chance to use it yet cause the build isn't done, but this think is close to an engeneering marvel. It is def built to take some abuse. I don't forsee any problems with it.
Since I already had SRE's on my steering, it was the best option for me. $150 is definately a fair price for the build quality and strength that are built into it.
If you get it, I don't think you will be dissapointed.
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
post #7 of 13 Old 04-22-2010, 04:20 PM
jdarg
I have the tera knuckle, soa on stock springs. My drag link limits my flex because the tera knuckle places it so high up...this one looks even worse in that respect.
I'm going to switch to the jb4x4 bracket. It puts the drag link in the most ideal spot for stock springs SOA. I'm not a fan of the stock steering but I'd rather carry some spares vs limit my flex given the choice.
If yuo are gonna run lift springs then it doesn't matter as much.
'94 YJ - SBC/AX15/231, SOA, 8.8, 34" swampers
'06 LJ Rubicon - 31" ATs, OME 2.5", belly-up skid, other junk
'75 CJ5 - 232/T14/D20, 'glass tub w/ 2" BL, otherwise stock
jdarg is offline
post #8 of 13 Old 04-22-2010, 04:39 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I agree, my comment fails to address the SOA crowd.
However, on my wife's '93 SOA YJ I used a true high steer kit, and I'm so pleased with it that I wouldn't even consider another option on an SOA application.
Max
Mean Max is offline
post #9 of 13 Old 04-22-2010, 04:45 PM
czjeeper
I put a JB4x4 bracket on my brother's YJ (SOA) and it works great.
I mention it because it is the most cost effective way, IMO.
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
post #10 of 13 Old 04-22-2010, 07:39 PM Thread Starter
nj95yj
yes i'm using lift springs for it so it should be ok
nj95yj is offline
post #11 of 13 Old 04-28-2015, 12:22 PM
bck4more
1987 YJ Wrangler
--notmyj-- Tried to send you a message but says your inbox is full.
I seen in some post that you have the the BTF cross over steering. I bought it for my SOA but Im having some issues with it on the tie rod its hitting my leaf spring on passenger side. Did you have this issue also could you share any pictures of it. Thanks
1987 4.2 automatic, 33" Pro Comp, 2100MC, nuttered, SOA, SYE,TW driveshaft
bck4more is offline
post #12 of 13 Old 04-28-2015, 12:54 PM
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
I'd call BTF first, before resurrecting a 5 yr old thread.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is online now
post #13 of 13 Old 04-28-2015, 12:58 PM
bck4more
1987 YJ Wrangler
Already have waiting to hear back
bck4more is offline
steering linkage bracket Rubikahn TJ Wrangler Technical Forum 14 04-26-2012 12:17 AM
BTF Steering Bracket notmyj YJ Wrangler Technical Forum 1 03-23-2010 08:47 PM
Steering stabilizer bracket... ikiz TJ Wrangler Technical Forum 4 03-06-2009 05:09 PM
pwr steering bracket 2000 tj JeepMud02 TJ Wrangler Technical Forum 0 07-29-2008 11:35 PM
Pic of 92 4.0 power steering bracket tr6 YJ Wrangler Technical Forum 2 10-07-2006 09:55 AM
