Quantcast soa springs are sagging - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > soa springs are sagging
Old 12-02-2008, 05:09 PM   #1
MCHERM
so heres the situation.... i have successfully done the soa with stock springs and have been riding on them for a good month or so and the springs especially the front, are starting to sag real bad. at the moment im sorta tight on cash and am looking for a way to make my jeep get back the lift and spring arch that it had before, without getting new springs. any ideas? or how have any of you all dealed with this same problem?
thanks alot
DJ
MCHERM is offline   Reply With Quote
Old 12-02-2008, 05:16 PM   #2
Macklin96
add-a-leafs would work
Macklin96 is offline   Reply With Quote
Old 12-02-2008, 05:36 PM   #3
only_in_a_yj
Maybe replace your springs with a better set of used stock ones. You can probably find somebody installing a lift and get their old ones for real cheap.
only_in_a_yj is offline   Reply With Quote
Old 12-02-2008, 06:00 PM   #4
girly04LJ
2009 JK Wrangler
Add a leaf but make sure you get full ones. short ones are cheep but they also break your stock springs.
girly04LJ is offline   Reply With Quote
Old 12-02-2008, 06:00 PM   #5
Joe Dillard
Free clues & suggestions
Joe Dillard's Avatar
For the extream tightwad measure the length of the main leaf & go to the junkyard and get single leafs that fits the bill which are slightly shorter than the main leaf is. Ensure it's not too long (unless you don't mind cutting it down) or too short, or too narrow, or too wide. Don't get leafs that's too thick either, or overly fatigued. Make sure the centerpin hole matches what you need as well.
Then get the stock clamps off as gingerly as possible (there is more than 1 factory style clamp). Some can be reused by the tightwad - while others can not. Mount the junkyard leaf under the main leaf & clamp it back together.
Myself, I would never go this route - I tend to buy the higher quality parts from the start. But this is an option for the tight budget folks.
Joe Dillard is online now   Reply With Quote
Old 12-02-2008, 06:39 PM   #6
MCHERM
I think i may go the add a leave route but wat do you mean by full length add a leaves?
thanks for the input everyone!!!!!
DJ
Old 12-02-2008, 06:44 PM   #7
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
DJ
Some add a leafs are meirly a "helper spring" that goes on the bottom of the pack usually shorter or as short as the smallest leaf. Full length ones go into the pack right under the main leaf and are almost the same length as the main.
http://i131.photobucket.com/albums/p...k_banner-1.gif
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline   Reply With Quote
Old 12-02-2008, 06:52 PM   #8
MCHERM
o ok i gotcha.
thanks
Old 12-02-2008, 07:27 PM   #9
ghost183
i had the same issues, but i added leafs in the pack, i used an old set of RC 4" lift springs, i tore them apart and added the 2nd largest and 4th largest spring from the main leaf to the front and rear stock pack, they rode slightly hard at first, till they set, now they are great
and oh, my YJ weighs 4300 pounds without me and tools.. with me and tools im estimating 4550-4600 pounds, so you might not want to add both leafs unless you plan on loading the jeep
[COLOR="darkred"][COLOR="blue"]My Daily Driver... [/COLOR]'92 Sahara, 4.0, Auto, A/C, Converted to NIB TF999 Auto 11/08, Relocated Breather, Temp Sender, Transpak, OEM Column Shift, TeraFlex Extreme Short Shaft SYE on '03 TJ 231J, NO T-Case Drop, Tattons 22 1/2", 7" Slip Rear CV Driveshaft, Tattons Front [COLOR="BLACK"]12" Slip[/COLOR] Driveshaft, NO Trackbars, SRS and SOA, OEM rear packs all around, JKS's, 1995 D30, Lockright, JB High Steer, & 3.73 gears, 1995 D35 w/ 30 Spline Ected, Alloy Axles & 3.73 gears, Custom built (by me) Anti Wrap bar using 2 rear tracbars, Welded and Sleeved "Thru Frame" Rear Shock Mounts, Rear Booms, '95 Dual Diaphram Booster and MC upgrade locking 35" Baja Claw Radials, 15x10 Eagle Alloys, 7" Flares, Ramsey Rep 8k, ARB Snorkel, Body Armor Double Hoop Front Bumper, Rocker and Corner Armor, Custom Built (by me) Rear Recovery Bumper/Carrier, Hilift, D-Rings, 30x6 Keeper, CB, Aftermarket Gauges in Gauge Works angled center dash, Trailmax Pro Seats and Center Console, 136 amp 7913 Alternator charging Dual Yellow Tops, 10 KC's = 1300 Watts of Lighting.......... 4480 lbs empty with my softtop, Jim = AKA Ghost183
[COLOR="blue"] Wifes, "once in a whiler"[/COLOR] ALREADY SOLD IT [SIZE="1"]'93 Sahara, 4.0, Auto, A/C, 4" RC kit, (Thanks again Ryan) Standard Shackles, 31x10.5x15 on OEM rims, everything else STOCK.. [/SIZE]
[COLOR="Blue"]Tow Vehicle... [/COLOR] '99 Tahoe, soon to be modded[/COLOR]
[QUOTE=Mean Max;6554202]BTW I drove the WJ to Dunkin' Donuts today and realized it has [B]GLASS[/B] side windows! What a concept! :D: :cheers2:[/QUOTE]
[CENTER][SIZE="2"] [COLOR="Black"]"Important Notice"
DUE TO RECENT BUDGET CUTS, STOCK MARKET PERFORMANCE, RISING COST OF ELECTRICITY, GAS AND OIL...
THE LIGHT AT THE END OF THE TUNNEL HAS BEEN TURNED OFF....
WE APOLOGIZE FOR THE INCONVENIENCE
Regards
THE GOVERNMENT[/COLOR][/SIZE][/CENTER]
ghost183 is offline   Reply With Quote
Old 12-02-2008, 10:26 PM   #10
fratis
fratis's Avatar
why do you need the lift back. are your tires grinding on the sheet metal as you drive down the road. my 2.5" springs are sagged almost flat and they work pretty darn good that way. dont listen to those who will rehash the "negative arch is bad for your springs stuff." everything is situational. i agree negative arch on a 4" lift spring would be bad. for a spring that is already almost flat it really isnt a factor.
fratis is offline   Reply With Quote
Old 12-02-2008, 11:07 PM   #11
ghost183
hey fratis.. you got a side shot of yours? and whos 2.5 springs are u using?
i did mine cause of my weight, but i was running a neg arch almost all the time, and in the rear, the arch would get worse under acceleration and the even more sagging, and not to mention wrap, so.. prolonged neg arch + wrap = u joint issues, besides, to be %100, my initial reasons were looks and brake dive in that order.. looks alot better to me with space between the tires and fender
Regards
Glock Forum
