soa in rear how high? - JeepForum.com
post #1 of 5 Old 04-12-2010, 12:32 PM Thread Starter
rcracer8
i have the procomp csc and i want to put a 8.8 in so i was going to go soa leafspring rear i was thinking of using waggy springs but i was thinking that would be higher than my front heres a pic theese are 31s by the way
http://www.jeepforum.com/forum/f12/my-build-92-yj-875543/
rcracer8 is offline
post #2 of 5 Old 04-12-2010, 01:54 PM
TSEJEEPERS
Yes going SOA is going to be taller in the rear than the front. With a SOA you are going to gain around 5 " of lift with stock springs.
By the way I think the price of Aluminum is up.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #3 of 5 Old 04-12-2010, 02:26 PM
youngYJ95
I'm not really sure but I would think that you could use coil spacers in the front since you wanna keep those. It would level out quite nice probably.
[Originally posted by rulppa: But no, there is no change is power.. and my arse-dyno is pretty accurate]
youngYJ95 is offline
post #4 of 5 Old 04-12-2010, 02:39 PM
themoz
How much lift is the coil conversion? It looks like about 4" over stock but pictures never tell the whole story, how old it is, etc.
SOA 8.8 vs. SUA D35 is a good 6-7" taller because the 8.8 axle tube is thicker and the SOA mounts (i.e. the "antiwrap" ones) are sometimes quite a bit taller than the stockers too. I think a waggy spring is 1-2" taller than a YJ spring as well so its probably gonna be a little taller back there, maybe 2-3" or so from the looks of things.
The axle wrap sucks with SOA unless you add an anti-wrap bar. You will break stuff without one if you are hard on it. Lotta pinion motion just doing basic accelerating and braking on the street without one.
themoz is offline
post #5 of 5 Old 04-12-2010, 03:03 PM Thread Starter
rcracer8
what if i do sua with waggy springs probly too low,would need shackles, the procomp is supposed to be 5"
rcracer8 is offline
High Rock Rear Bumper YJMeadows381 YJ Wrangler Technical Forum 0 05-02-2008 09:12 AM
High back rear seat? Chris_ TJ Wrangler Technical Forum 33 05-24-2007 02:25 PM
Tj Rear Sitting High WJtech TJ Wrangler Technical Forum 12 04-01-2007 05:20 PM
Rear axle shaft-high strength ok? Paul DK TJ Wrangler Technical Forum 6 10-10-2006 07:46 AM
High-lift in the front or rear? TJer TJ Wrangler Technical Forum 15 04-27-2004 04:42 PM
