Quantcast SOA with RE 2.5" springs - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > SOA with RE 2.5" springs
TJ 5.25" Speaker Adapters - NalinMFGSpartan Lockers FREE SHIPPING Excellent PricesRough Country Deals at JeepHut.com
Old 03-08-2010, 02:56 AM   #1
Larry93
Larry93's Avatar
I am about to do a SOA to my jeep finally & cannot decide if my 2.5 RE SUA springs will be to much lift for the SOA. Thay are 4 years old so there is some sag. I will be sticking with 33X12.5 tire, & will use stock height shackles.
If it is on the high end, is machining down the SOA axle perches to remove some lift enough?
This is DD driver, that 2% of the time sees the trail.
Larry93 is offline   Reply With Quote
Old 03-08-2010, 08:59 AM   #2
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
This is my old YJ on 37's, with 2.5" OME springs, 5/8" MORE shackles and SOA.
A pic of a rig I did the same mods too, on 35's with TJ (IIRC) flares
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.The Cherylkee....
1998 Range Rover 4.6 HSE
2000 4.7 4WD WJ with a rebuilt motor.
4.3/700r4/new frame buildup (YJ)....
http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/
Years to gain the hands on experience, and offer it freely.
Minutes to gain the knowledge from the internet, and quote it just as freely.
Choose wisely!
leftlanetruckin is offline   Reply With Quote
Old 03-11-2010, 10:28 PM   #3
Larry93
Larry93's Avatar
That might be to much. I guess it is SOA with the 2.5" or just buy the SUA 4.5" RE's.
Old 03-12-2010, 01:16 AM   #4
highrolrcustoms
highrolrcustoms's Avatar
here is mine....its a 7.5" Rocky Road SOA Kit, with 2.5" lift springs and 2" body. clearing 37x13.50s with ease
p.s. She is 5'7"
95 yj juggy SOA, factory springs, BTF rear stretch kit with relocated stock spring hangers, custom wagoneer front spring packs. 106" wheelbase. comp cut, full width ford 78/79 dana 60hp front axle with 538 gears and full spool, ford sterling 10.25 full width rear axle with 538 gears welded and disc brake conversion, 39.5x13.50 super swamper iroks on 15x8 Allied wheels 3.5" backspacing with DIY beadlocks, High Steer with 1.5x.250 dom tubing, Full Hydro steering, custom cage, custom tube doors, rci 2161a fuel cell,M.O.R.E. Antiwrap bar, smitty SRC rock crawler front bumper, Pro Comp 55 lights,smitty xrc 8 winch, Hi-lift hood mount jack, rugged ridge sye, cv driveshaft, jk motor mount lift, smittybuilt rock sliders with tubes, btf comp cut corners, 3 racing seats with simpson 5 point harnesses
UPDATE....getting 4 linked front and rear with 16" coilovers in front and 16" air shocks in rear as we speak.. also being backhalfed with tube :)
"THE MORE YA PLAY WITH IT.....THE BIGGER IT GETS"
highrolrcustoms is offline   Reply With Quote
Old 03-12-2010, 05:00 AM   #5
Joe Dillard
Free clues & suggestions
Joe Dillard's Avatar
If the above is correct - don't bother.
Joe Dillard is offline   Reply With Quote
Old 03-12-2010, 05:34 AM   #6
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
I agree with Joe 1000%. Don't waste your time/effort/money doing SOA for a road Jeep.
'93 YJ, '02 GM 4.3 Vortec V6, SOA, dual ARB's, 8.8+D30(w/WarnHubs), 4.88 gears, 35" Trxus M/T's, AX15, 15x7 wheels, NP231+4:1+SYE+2LO, York OBA, Warn M8000, no top or doors Apr-Oct.
Member and Web guy: New Mexico 4 Wheelers
JeeperDon is offline   Reply With Quote
Old 03-12-2010, 07:16 AM   #7
boggerjeep
i have 1" black diamond springs with soa and 2" body lift and 35" tires and i would like to remove the body lift. its not needed for 35s with the amount of trimming i've done.
sell your home. buy a Jeep and a shop. cost about the same to have.
boggerjeep is offline   Reply With Quote
Old 03-12-2010, 01:39 PM   #8
Larry93
Larry93's Avatar
Thank you for the replys. I will see what I am going to do. Using the 2.5RE on a SOA is just to much lift for what I want. Joe, I know you are right on. Problem I find with most people, when it is your car it is hard to listen to common sense.
Old 03-12-2010, 02:47 PM   #9
Joe Dillard
Often so true with some folks. Build it however you wish, but be advised that 2.5" leafs SOA does give quit a bit of lift.
Old 03-12-2010, 02:51 PM   #10
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
You asked about springs, but it's way more than that. If you are looking for rational reasons to remind you it's a bad idea, it's guaranteed you will have to spend money/time/effort on steering, then there is the drive line angles and SYE and shaft lengths, then sway and track bar adjustments (since it's a DD). Buy some nice wheels and move on
Old 03-13-2010, 06:39 AM   #11
Larry93
Larry93's Avatar
I was plotting some of your points. My SYE driveshaft is too long as it stands so it would work. I ditched my sway already. I am happy with me wheels already thanks. The steering is what is really the concern.
I think it is certain I am going to eat the $600 to go with RE 4.5" SUA springs/stock shackle length and loose the 2.5"RE with 1" lift shackles.
I was figuring $600 deep into a SUA, when $600 & slightly + would cover the SOA with my 2.5"RE. That is with steering/trac/etc...
Glock Forum
