Soa Question - JeepForum.com
post #1 of 7 Old 04-18-2010, 08:25 PM Thread Starter
jeepaholic91
Soa Question
I recently installed a SYE and cv driveshaft that measured out to 17 3/4". im currently sittin on a 4" sus lift and the driveshafter fits fine. i want to go soa w/ my stock spring which will giv me an inch and half more of lift a total of 5 and a half. will this inch and half cause my driveshaft to be too short?
Louisiana Tech University
jeepaholic91 is offline
post #2 of 7 Old 04-18-2010, 08:31 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Are you sticking with the D35 rear axle?
That's partially going to depend on how much slip is remaining after the lift.
The 1.5" gain in height alone is not going to be the only contributing factor if the SOA is dialed correctly. You should have more droop too, which means a greater amount of slip will be necessary.
If you are going to use 15 year old stock leafs & go SOA - expect those leafs to be short lived if you wheel it at all.
Joe Dillard is offline
post #3 of 7 Old 04-18-2010, 08:35 PM Thread Starter
jeepaholic91
yes im stickin with the d35.
explain what you mean about the "slip remaining" please.
post #4 of 7 Old 04-18-2010, 08:38 PM
CreepyCrawler95
where the driveshaft slips there is a certain amount of slip that will occur untill the driveshaft comes apart at the center. you should be fine on stock springs though
CreepyCrawler95 is offline
post #5 of 7 Old 04-18-2010, 08:40 PM Thread Starter
jeepaholic91
that's good to know! Is there anything else i should take into consideration?
post #6 of 7 Old 04-18-2010, 08:44 PM
CreepyCrawler95
be sure to find the right angle measurements (spring perches, pinion angle, etc.) invest in high steer from the git-go or cross over steering. longer shocks preferably bilstein or old man emu provide softest rides. if you know how to you can snail wrap your leaf packs or by a traction bar for the rear.
post #7 of 7 Old 04-18-2010, 11:23 PM
fratis
fratis's Avatar
dont be dead set on 5.5" of lift. i know this gets thrown around allot but the reality can be different. my worn 2.5" leaves puts my soa about where a fresh 4" lift would be.
fratis is offline
Lift/Tires question and Cleaning soft top & engine question Bryan_16 TJ Wrangler Technical Forum 16 05-19-2012 03:25 PM
Front sway bar question + bonus disco question WranglerTom TJ Wrangler Technical Forum 7 12-02-2011 08:13 AM
1988 carberator question and wiring (general) question prljeep YJ Wrangler Technical Forum 15 05-08-2009 11:50 AM
quick connecting rod question and tourqe wrench question???? johnrezz YJ Wrangler Technical Forum 2 10-18-2008 07:20 PM
Tire question(noob question but just a quick answer needed) 07SilverX JK Wrangler Technical Forum 3 12-25-2007 03:35 PM
