SOA/OTK/"One Ton" tie rod question(s) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > SOA/OTK/"One Ton" tie rod question(s)
10,500 Lb Winch Rugged Ridge1987-1990 Jeep Wrangler Engine Oil Pan for L6 4.2LBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 04-21-2015, 12:08 PM   #1
87TPIYJ
1987 YJ Wrangler
I have a couple of questions I am having a little difficulty using that nice "search' button to find the answers. I bent my tie rod on a wheeling trip this weekend so I am looking at replacement/upgrade options.
My current set up:
-SOA with 6 Leaf 0" lift springs.
-JB 4x4 Crossover steering bracket
-Home made 1-1/2" .25 wall DOM drag link (stock TRE's)
-Stock Tie rod
I am looking at building one out of ES2234(R&L) TRE's and 1-1/2" .25 wall DOM. One question that came up is will the HD tie rod clear a ruffstuff D30 diff cover? I would like to avoid the offset TRE's due to availability and price. I would need to ream for then new TRE's and that led to the next question. Is any one successfully running their tie rod OTK with the chevy TRE's on a SOA set up? It looks like it would be really close to interfering with the spring. I would like to get the tie rod up out of the way as much as possible. Trying to figure these things out before I bust out the wallet on some parts. Thanks!
Picture for reference.
87 YJ, 350 TPI, NV4500, 35x12.50x17, SOA, Locked front, 8.8 LSD rear, Flat skid
87TPIYJ is offline   Reply With Quote Quick reply to this message
Unread 04-21-2015, 02:00 PM   #2
Reno72
I'm not SOA but can tell you I run the RuffStuff DOM with 1 ton Tre's OTK and clearance of the Diff is close. I have an ARB cover and do not contact it, a cover that stuck out furthur could be an issue. My understanding is just OTK will not work with SOA, you need a high steer set up.
"Says the guy driving the plastic Barbie Jeep". JLH
Reno72 is offline   Reply With Quote Quick reply to this message
Unread 04-21-2015, 03:11 PM   #3
timatoe
timatoe's Avatar
I would say no. I've got basically the same as you SOA, JB4x4 bracket etc. I too bent the hell out of my tie rod and went with a similar setup but used the RS offset tie rods. My stock tie rod would almost rub on the Rock Crusher cover. Plenty of room now.
These pics are from when I did the install, so it wasn't all tightened up yet (because someone always points out that they're loose).
timatoe is offline   Reply With Quote Quick reply to this message
Unread 04-21-2015, 04:49 PM   #4
87TPIYJ
1987 YJ Wrangler
If it fits I would like to use normal TRE's even if it's UTK. Has anyone been successful using particularly the ruffstuff diff cover with the "one ton" tie rod? I know it's not truly "one ton" but it's what everyone calls it.
Sent from AutoGuide.com Free App
Unread 04-21-2015, 09:20 PM   #5
rwinter
rwinter's Avatar
1987 YJ Wrangler
My current set up:
-Stock Tie rod
I had rock crusher diff covers and it wasn't a problem.
http://www.jeepforum.com/forum/f12/l...-build-866779/
rwinter is offline   Reply With Quote Quick reply to this message
Unread 04-21-2015, 09:56 PM   #6
timatoe
timatoe's Avatar
I don't think you can run it OTK, because the springs are in the way.
Unread 04-22-2015, 08:00 PM   #7
87TPIYJ
1987 YJ Wrangler
Looks like I'm just going to bite the bullet with the offset TRE'S. I'd rather get something I know is going to work try and save money on something that might work.
Unread 04-23-2015, 05:03 AM   #8
fratis
fratis's Avatar
clearance the diff cover.
-insert meaningless out-of-place political diatribe-
fratis is offline   Reply With Quote Quick reply to this message
Unread 04-23-2015, 05:30 AM   #9
calvynandhobbs
I don't know the crossover steering bracket you are using at all, but my SOA YJ is getting the RuffStuff OTK 1-ton kit. I've checked for clearance and I can run OTK, but I'm also SOA running a waggie 44 with Dodge outers and flat tops, which I think gives me a little more height to get above the springs than what you're doing.
94 YJ - work in progress
calvynandhobbs is offline   Reply With Quote Quick reply to this message
