Quantcast SOA Major Bumb Steer/Death Wable have no clue what to do. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > SOA Major Bumb Steer/Death Wable have no clue what to do.
Old 06-13-2009, 01:46 PM   #1
mudcrawler90
web wheeler
mudcrawler90's Avatar
OK heres the problem my dad and I installed 2" shackels and a SOA and have a huge bump steer problem and do not know what to do next.
We have a stabilizer, drom pitman arm, it was alinged yesterday, the sway bar is still hooked up (with discos), the drag link and tie rod are parellel (relocation bracket on the tie rod). Pic shows what my steering looks like now.
Are there any tricks or aftermarket parts we can use to help aleveate this problem because this is almost scarry to drive.
I know there are othe post but most are for TJ's and I couldn't anything for a SOA.
Having to tow your Jeep down the road with a stock truck is like water skiing naked, its embarrassing, your being pulled by a single line, and it hurts a little but in the end all you can do is look back on it and laugh!
/l , [____],
l------L--[]lllllll[]-_
()_) ()_)==♠=)_)
mudcrawler90 is offline   Reply With Quote
Old 06-13-2009, 02:09 PM   #2
djrodrigue
With that much lift you are going to need more than just a dropped pitman arm to correct that steering geometry.
djrodrigue is offline   Reply With Quote
Old 06-13-2009, 02:11 PM   #3
djrodrigue
If you have the funds... here is a smoking deal on a hi-steer kit.... http://www.4wheelparts.com/prodDetail.aspx?partNo=TERHSK&jeep-parts=true
especially this weekend, you would get 20 percent off
Old 06-13-2009, 04:56 PM   #4
Joe Dillard
Free clues & suggestions
Joe Dillard's Avatar
First go back to whoever it was who informed you to build your SOA like that & give 'em a swift hard kick in the groin.
Let me guess....that piece of metal that's attached to the vacuum disco that you are using to raise the lower end of the tracbar bracket, is a strait piece of metal with two holes drilled in it, and is allowed to "swing" as the tracbar pivots.
Correct?
Joe Dillard is online now   Reply With Quote
Old 06-13-2009, 05:30 PM   #5
mudcrawler90
web wheeler
Joe:
No the track bar extention has a piece welded to the bottem of it that hooks to the disco and stops it from swinging. I got the Jeep with the front done, i had to do the back (sweet deal chech profile for more) whats wrong with it, im new to jeeps.
djrodrigue: I wish i had those kind of funds even with it 20% off.
/l , [____],
()_) ()_)==♠=)_)
Old 06-13-2009, 05:41 PM   #6
HARLEYX2
1987 YJ Wrangler
It looks like your draglink and track bar are parllel. Not the tie rod.
HARLEYX2 is offline   Reply With Quote
Old 06-13-2009, 05:46 PM   #7
bigredcherokee
You need to correct that steering like joe said . Order the JB4x4 bracket. Get ride of the track bar and the drop pitmand and go back with Stock and you should be ok.
Harly is right the Track isn't parllel but that aside junk it and get the JB kit you will be very happy.
For those of you in Louisiana visit
www.bayoujeepersoffroad.com
bigredcherokee is offline   Reply With Quote
Old 06-13-2009, 06:08 PM   #8
mudcrawler90
web wheeler
O i see i had the wrong links parellel. That JB4x4 bracket looks good and it far from the tereflex price. but i'm still open for any other ideas (sorry i only make $60 a week).
/l , [____],
()_) ()_)==♠=)_)
Old 06-13-2009, 06:33 PM   #9
Digger 5
The steering angle looks ok but I don't know about the bottom bolt for the track bar mount. The bottom bolt looks like it can pivot which negates any function of the track bar. The track bar SHOULD prevent any bump steer.
Death wobble is frequently caused by bad caster angle. With a new SOA, that's where you should first look.
Jeepin's not a hobby, it's a lifestyle!!
Digger 5 is offline   Reply With Quote
Old 06-13-2009, 06:56 PM   #10
Brads_nky_yj
Lose your track bar completely, dont ask just do it!
Buy the JB4x4 bracket and install that (and order the extended tie rod that comes with it if you need it as well)
You need to get the drag link above the leafs at least!
93 YJ - SOLD
Brads_nky_yj is offline   Reply With Quote
Old 06-13-2009, 06:58 PM   #11
mudcrawler90
web wheeler
I know it looks like the track bar can pivot but we built and tested ourselvs and it will not pivot so that is not the problem.
/l , [____],
()_) ()_)==♠=)_)
Old 06-13-2009, 07:20 PM   #12
HARLEYX2
1987 YJ Wrangler
What is your caster angle?
Old 06-13-2009, 07:32 PM   #13
Ironworker709
Ole Ironhead
Ironworker709's Avatar
The bump steer is being caused by the trac bar ,it is at an angle downward,when hitting a bump and the axles moves up or down the axle shifts side to side along with the trac bar because it is at an angle and should be parallel with the axle.
Take the trac bar off and see how it handles and rides without it,i KNOW you'll just ditch it then.
The death wobble is either caused by a bad caster angle or ball joints and/or tie rods
Ironworker709 is offline   Reply With Quote
Old 06-13-2009, 07:41 PM   #14
jeepin1995
jeepin1995's Avatar
it's not the caster causing the bumpsteer..... i ran my SOA exactly like that (minus track bar) for a year.... bumpsteer like nobody's business..... i ordered the JB4x4 bracket and it's perfect now.
here's what i would do.....
ditch the sway bar AND track bar..... they are overrated. leave the drop pitman arm, and then get the JB4x4 bracket. that's the CHEAPEST option.
by the looks of it, with the JB bracket and the Drop pitman arm, your draglink will be perfect. here is a pic of mine:
______
/l,[____],
l---L -[]lllllll[]
()_) ()_)---)_)
98 TJ stock for now
WWW.FLATLANDROCKCRAWLERS.COM
350 in my YJ.....
http://www.jeepforum.com/forum/f12/my-350-swap-518364/
build thread:
http://www.jeepforum.com/forum/f22/yj-dana-60-70-build-1122902/
jeepin1995 is offline   Reply With Quote
Old 06-13-2009, 07:42 PM   #15
Digger 5
The track bar was designed to help prevent bumpsteer. It maintains the distance of the spring from the pitman arm under compression. Removal will cause more bumpsteer. This is one of the reasons TJs have trac bars.
Glock Forum
