soa lift - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > soa lift
XT (ExtremeTerrain.com) has Barricade Off-Road Armor!ROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail Nitro Gear Packages Now Available at Rockridge 4wd
Unread 03-19-2015, 05:56 PM   #1
valk241
soa lift
Do I need to do anything to my driveshaft to do a spring over I am adding in a 8.8 and realized I should put in a lift while I'm add it
valk241 is offline   Reply With Quote Quick reply to this message
Unread 03-19-2015, 07:12 PM   #2
valk241
I'm talking about front drive shaft
Unread 03-19-2015, 07:19 PM   #3
WakeDoctor
This should be fun.
WakeDoctor is offline   Reply With Quote Quick reply to this message
Unread 03-19-2015, 07:26 PM   #4
Beachcruiser
1987 YJ Wrangler
Hooo boy!
Short answer: yes.
Real answer: just about every part of your suspension, axles & steering need to be modified to make a SOA lift work properly & be safe on the road. This is assuming you are trying to run 35" or larger tires.
You should probably read up extensively as to what's involved before you start randomly buying parts or turning wrenches.
probably out breaking stuff.
Beachcruiser is offline   Reply With Quote Quick reply to this message
Unread 03-19-2015, 07:34 PM   #5
valk241
I've read that you don't need something in front driveshaft but I have everything covered for the rear and steering I'm just probably do 33's
Unread 03-19-2015, 08:07 PM   #6
fishadventure
Need is a very subjective word. But the front driveshaft will need addressing somehow.
How many old threads actually convince *you* to read all 36 pages? http://www.jeepforum.com/forum/f12/length-envy-build-thread-629700/
fishadventure is offline   Reply With Quote Quick reply to this message
Unread 03-19-2015, 08:14 PM   #7
valk241
What should I do to it then so it will work
Unread 03-19-2015, 08:16 PM   #8
TSEJEEPERS
Front driveshaft should be good.
You will however need a SYE and CV driveshaft for the rear.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list. www.mijc.org
TSEJEEPERS is offline   Reply With Quote Quick reply to this message
Unread 03-19-2015, 08:27 PM   #9
valk241
I'm buying that tomorrow and I bought a pitman arm drop
Unread 03-19-2015, 08:48 PM   #10
Anticanman
The Thunder Chunky
Anticanman's Avatar
I would go with a TJ front driveshaft and transfer case yoke. That's just me though.
Luck Favours The Prepared
"Whiskey is for drinking, Water is for fighting over" - Mark Twain
Anticanman is offline   Reply With Quote Quick reply to this message
Unread 03-20-2015, 04:27 AM   #11
Louie4
Powah Injanir
Louie4's Avatar
You probably want to measure the yoke centers when you're done. Then give that information to a driveline shop. I got mine from Tom Wood. I'm about finished with my front spring over so I will need a lengthened driveshaft up front.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Poison Spyder Fender Install
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is offline   Reply With Quote Quick reply to this message
Unread 03-20-2015, 12:34 PM   #12
fratis
fratis's Avatar
On a mild and functional SOA the stock driveshaft should be ok. Best to focus on more important elements and then revisit the front shaft issue if needed.
-insert meaningless out-of-place political diatribe-
fratis is offline   Reply With Quote Quick reply to this message
Unread 03-20-2015, 12:45 PM   #13
Jeepsr4me
How are you going to do the steering... I hope the hell not like this.
or this...
it should look like this..
Jeepsr4me is offline   Reply With Quote Quick reply to this message
Unread 03-20-2015, 02:38 PM   #14
imstillatwork
I like the reinforced 'Z' drag link. F for effort.
Why do people put so much time into doing things wrong. It's like they want to go out of their way and spend more, just to do it wrong. Blah. I don't get people.
imstillatwork is offline   Reply With Quote Quick reply to this message
Unread 03-20-2015, 03:02 PM   #15
Steve707
Is that a spacer under the heim on the drag link?
Steve707 is online now   Reply With Quote Quick reply to this message
