Soa conversion Question - JeepForum.com
post #1 of 4 Old 05-17-2010, 08:19 PM Thread Starter
tjalmeida
hi everyone, i was looking through craigslist and came across a jeep with a good front axel that is already SOA. If i were to buy the axel do i need to do anything else to make my yj SOA or is that all i need?
Thanks
Tyler
tjalmeida is offline
post #2 of 4 Old 05-17-2010, 08:22 PM
justanotherjpr
If the front axle is already set up for SOA you will need to SOA or lift your rear to match. You'll also need new shocks, brake lines, SYE, and steering. Consider also adding a leaf to your springs to prevent them from getting ruined. Really depends on how much you get from the donor Jeep. SOA conversions are not cheap.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #3 of 4 Old 05-17-2010, 08:23 PM
Area.3.Fiftyone
If I were you I would read some posts here before asking something like that.
This has been covered way too many times for anyone to try and explain it to you.
I suggest searching for "SOA" in the technical forums. This should yield plenty of useful information.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #4 of 4 Old 05-17-2010, 08:24 PM
hondacr21
hondacr21's Avatar
you will need to SOA your rear axle and depending on what is done to the front axle steering might need to be dealt with it depends on how they did it. Will need a SYE and CV rear driveshaft. Shocks will be needed.
1995 Sahara, Borla header, Rear stretch 103" wheelbase, Sniper Fab Comp Corners with 3" flare, SOA with .75" SL, 2 1/2" Rancho lift on 37"s MTR's on 15x8 eagle alloys. JB4x4 steering bracket, M.O.R.E., 8.8 with limited slip and 4.10's, AA SYE, modified XJ front driveshaft, Superwinch EPi 9.0, homemade boatsides, 6 point cage.
hondacr21 is offline
4.0 Conversion question pcphenom YJ Wrangler Technical Forum 10 11-23-2010 11:10 PM
YJ V8 conversion question? jeepdude25 YJ Wrangler Technical Forum 11 10-29-2009 08:32 PM
Conversion Question CliffB JK Wrangler Technical Forum 11 03-27-2007 08:59 PM
Question about the HID conversion aug TJ Wrangler Technical Forum 6 03-22-2007 07:48 AM
350 conversion question???? wild_weazel YJ Wrangler Technical Forum 15 07-30-2003 08:14 AM
