SOA+4.5"=??? - Page 2 - JeepForum.com
post #16 of 20 Old 06-25-2002, 03:54 AM
cj7traildriver
Geez dude 4.5 lift spring's plus a SOA. SOA is spring over axle if you don't know and that alone is a 5.5 inch lift you add 4.5 to that you will have 10 inches of lift can yah fit 36 inch tires yeah and with room to spare plus will have many drive line issue not to mention axle wrap issues. For a daily driven rig, you can go 36 lol but dude isn't going to ride or handle anything like it does now. When tires get larger then 30's they don't tend to ride well meaning can be balanced perfect but will still shake bounce whatever. You'r talking about a short wheel based light jeep. Im not tryen to talk you out of it just informing so not suprised, and there are other issue's then I listed or the guys above listed modifying is a world of it's own.
Jeep what else matters.
cj7traildriver is offline
post #17 of 20 Old 06-25-2002, 08:18 AM Thread Starter
ScratchingWezel
ya I know how ruff they are my friend has a 97 with 35's on it. I am preparied.
1991 Jeep Sahara Green
ScratchingWezel is offline
post #18 of 20 Old 06-25-2002, 02:21 PM
YJ_90
If all your trying to accomplish is running the 36" swamps then just do a spring over and call it good. But don't waste your money on buying a kit. All you need is new spring perches, Extended brake lines, a drop pitman arm, a SYE kit, and a CV driveshaft. I also know plenty of people who run 38's and larger with a spring-over and 2.5" lift springs. But if ya wanna go real large buy a 4.5".
I also highly recommend getting new axles, the 44's you talked about would be perfect. no need for a 60. Hell since your spending all that money drop a V-8 into the mix.
Member #26-Black Jeep Club
"Get the Strap"
YJ_90 is offline
post #19 of 20 Old 06-25-2002, 06:24 PM
bigblueyj
no need for 4.5'' spring plus soa to keep the c.o.g. down. Flat fender the front hack out the back or rear tj flares and i look at bds 2.5'' springs that be right for 36's
bigblueyj is offline
post #20 of 20 Old 06-25-2002, 09:58 PM Thread Starter
ScratchingWezel
Thank you for all the advice i think i will go for the 2.5" and the tj style fenders. Thank You
Dealer says "dirty throttle body" and needs "to flush/clean the injectors"..... WheelinTJ2004 TJ Wrangler Technical Forum 18 05-17-2010 11:54 AM
What seperates the "Weekend Warrior" from the "Trail Truck" ArrizX Wrangler General Discussion 27 01-28-2010 02:59 PM
mettalic "clank", "pop", "squeak" txpedro TJ Wrangler Technical Forum 2 03-21-2007 05:45 PM
Can't locate "Switched" and "unswitched" wire leads behind the glove box on 04 TJ Sparty TJ Wrangler Technical Forum 4 04-03-2004 01:24 PM
