So.. rebuilding the AX5 - JeepForum.com
post #1 of 5 Old 01-17-2013, 03:14 PM Thread Starter
hobgoblin11
Hi all.. my first post. Just got a 92 YJ 4 cylinder with an AX5.
Been doing a lot of research and it appears the AX5 is a pretty sub par tranny prone to various issues.
Question is.. can you build them to be semi-reliable? What are the weaknesses and what can be done to make any imrpovements? Id love to switch to an AX15 but that just isnt feasible for the time being..
Thanks in advance for any feedback!
hobgoblin11 is offline
post #2 of 5 Old 01-18-2013, 12:25 AM
Nickabis
Welcome to the forum! As for the ax5, yeah it isn't the greatest tranny but I have seen them get used pretty hard. I lost a tooth on my cluster in mine, had to skip 3rd gear all the way home from a snow run.
As for making it stronger, I don't think there is a way, general maintenance will probably be the best thing to do. I don't know if rebuilding it would be worth it, the ax15 swap may be cheaper, I know you said not feasible. I found a used ax5 for $75 on craigslist from a v8 swap. Swapped that with my bad one, changed the oil, and it's been working great. That's my thoughts, hope it helps.
Nickabis is offline
post #3 of 5 Old 01-18-2013, 05:49 AM
bestos
do a NV3550 swap
1995 YJ - 33" BFG KM2 - 4.88 w/ Aussie front locker. 2.5" OME. 5/8" shackle. 1" JKS body.
1991 YJ - 4.0 - Stock and banged up and recent purchase
bestos is offline
post #4 of 5 Old 01-18-2013, 06:14 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
You should install a 5th gear clip collar.
http://www.jeepforum.com/forum/f12/a...emoval-908252/
I rebuild quite a few AX-5 transmissions & I won't do one without the collar installation.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #5 of 5 Old 01-18-2013, 10:39 AM Thread Starter
hobgoblin11
Max
I love that thread Max. esepcially the pic of the ground gears UGH
Do you have a link for that clip collar? My engine is currently out so Im thinking I may just rebuild the tranny while the motor is getting done.
