So I went wheeling and THIS happened...
| Rock Krawler Suspension's for BLOW OUT prices!!! | Great deals on Mickey Thompson Tires @ Jeephut.com | RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com |
#1 | |
![]() Shackle inversion or something else? I don't know when it happened because it has not effected my ride at all. (Still bumpy as hell). I have to take the interstate home from Ocala and maintain 60-70mph speeds for a couple hours to get home. I'm staying the night here in Ocala but am wondering what I should do? I heard that if I just beat it back with a BMFH it will stay bent up and lift the front right corner. Deadly to drive? Just fine? Excuse to finally lift it? ![]()
/l , [____], l---L--[]lllllll[]-_ ()_) ()_)==@=)_) |
#2 |
ehhh... from what I can see, the whole spring is bent, not sure if I would want to drive 60-70 for hours on a bent spring like that... I would be worried that the shackle would come apart while driving and the jeep would endo... I personally would replace the spring before I drove it home.
79 CJ5 Silver Anniversary Edition... revived & sold *sniff 91 YJ 4.0 L, with some stuff bolted to it... 3/4 Ton YJ 91 2 door Cherocar... in progress BeachMetalWorks Custom CNC cut Jeep parts & more |
#3 |
Here are a couple more pics from different angles.
![]() ![]() It looks pretty rough but rides just like normal.
#4 |
lost in the woods
I would clean it up to really see what is what. Then assay the damage. If the end is still good and the bolts in the shackle are good I could not see a reason not to be able to drive it home with stops to check it. But I would not be doing anything over 55 just in case XXXxxXXX happens.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 . For those who have not figured this out I'm old school but can handle the new too. |
#5 |
I'll take the back roads home tomorrow then. I'm still not sure when I'll be able to get new springs so I'll be driving it like this for probably a couple of weeks.
Any suggestions on what could have prevented this? I thought boomerang shackles were made to prevent this problem? Are there stronger springs that will hold their shape better? ![]()
#6 |
you needed a 3rd bolt in the middle of the booms to help prevent your springs from becoming inverted.
#7 |
When inverted, the bolt hole on the front shackles doesn't hit the frame before the spring pack eye does.
I went and checked to make sure, the bottom bolt hits the frame before the center one would. In the back however, it looks like it would save the spring pack.
#8 |
Youch!!! That looks like it hurt
#9 |
you are missing the center bolt on your shackle..it looks like your spring bent..in trail speak.."it folded like a taco, bro"
#10 |
XJ on 37's
boomerang shackles are the only cure for an inverted shackle. a 3rd bolt does nothing, except rest against the frame like it is now. the boomerang shape with the 3rd bolt is what stops it from inverting, not straight shackles with a 3rd bolt....
did it on my old yj, it cost me a new old man emu main leaf though.... the leaf spring, or at least the main leaf, is screwed. try to get another leaf spring on there asap. martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.The Cherylkee.... 1998 Range Rover 4.6 HSE 2000 4.7 4WD WJ with a rebuilt motor. 4.3/700r4/new frame buildup (YJ).... http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/ Years to gain the hands on experience, and offer it freely. Minutes to gain the knowledge from the internet, and quote it just as freely. Choose wisely! |
#11 |
Booms wont stop the spring from folding under like that unless you have some kinda of stop behind it or something to prevent it from moving more then a certain degree back. booms were really designed to clear things like bumpers that would limit flex.
#12 |
only in a jeep can you have that kinda carnage in your suspension and it still drives like normal lol.
correction: only in a yj
89 yj stock- sold 92 yj stock- sold 97 tj 2"bb,31" tires- sold 95 yj soa,350 v8,sm465,44" tires,d60,14bolt- sold 95 yj soa,350v8,700r4,35" tires,d30, 8.8, fuel cell- sold current ride-97 TJ- 86k miles, 4cyl auto, black casinos, 31" BFG A/T |
#13 |
I drove it down the interstate at 65-75mph for two hours to get home this morning.
The Jeep ran just like it always does with no unusual vibes or anything. I need to replace the leaf but may not have the chance for a little due to cash. I wasn't expecting such an expensive injury to my Heep I guess I plan on using the RE 2.5" lift kit to replace them all now.Any other suggestions on where to get stock leaves or whether the RC 2.5" is worth it or not would be cool.
#14 |
IMO don't bother with the RC dude, go with the RE
90 yj with RC 4in lift. 2 in BL, 5/8 boomerang shackels, 35 in. Mud Kings 81'C10 lowered,350, mildly built :] |
#15 |
Willing to pay the difference?
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
