so I just bought an 89 YJ that's been sitting for 2 years... - JeepForum.com
post #1 of 12 Old 04-05-2013, 02:25 PM Thread Starter
airn890
hey guys. so like the title says I just bought a yj that has a rebuilt engine and tranny but has been sitting for 2 years. the owner said it needs the clutch to be bled as well as the brakes. the clutch will just go down to the floor and not put the car into gear. does this sound like it just needs to be bled?
airn890 is offline
post #2 of 12 Old 04-05-2013, 02:31 PM
bgredjeep
1987 YJ Wrangler
Is there fluid in the clutch master? If not, when you add fluid does it leak out under the Jeep? Should be pretty easy to check.
bgredjeep is offline
post #3 of 12 Old 04-09-2013, 01:33 PM Thread Starter
airn890
yes there is fluid in there, next step lol? thanks in advance
airn890 is offline
post #4 of 12 Old 04-09-2013, 01:38 PM
Reddy89
Bleed the clutch.
Reddy89 is offline
post #5 of 12 Old 04-09-2013, 01:58 PM Thread Starter
airn890
so i went underneath the car to check out where you bleed from, i am not mechanically inclined btw if you couldnt tell but there seems to be some black rubber piece missing when i compared it to a video on youtube. Thoughts?
airn890 is offline
post #6 of 12 Old 04-09-2013, 02:03 PM
Hip2BSQ
Ya, there should be a rubber gromett that both lines go through into the bell housing.
Hip2BSQ is offline
post #7 of 12 Old 04-09-2013, 03:14 PM
bgredjeep
1987 YJ Wrangler
It's just for dirt/debris. Shouldn't make a difference as far as the clutch working. The bleeder is right at the end of the hose coming back out of the bell housing. Get to it.
post #8 of 12 Old 04-09-2013, 03:19 PM Thread Starter
airn890
just had a mobile mechanic bleed it and it didn't work. seemed like an honest guy and he had jeep knowledge. told me its the slave cylinder and it's internal so it'll be costly to fix. he told me $200 in labor which I think is pretty cheap
airn890 is offline
post #9 of 12 Old 04-16-2013, 09:53 PM
LordOfTheSith
You have my condolences
LordOfTheSith is offline
post #10 of 12 Old 04-16-2013, 10:36 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
1. fill out our profile.
2. Perfect excuse to do an External SLave Mod > http://www.jeepforum.com/forum/f12/l...p-pics-965067/
3. Not mechanically inclined and YJ owner are terms usually reserved for the high school parking lot and involves lip gloss. Buy a manual and get greazy!
91 YJ "Alice" 4.0L, AX-15, NP 231 w/HnT Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #11 of 12 Old 04-16-2013, 11:51 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Internal slave cylinders are a two hour: three beer job for two people. Its quite simple after you start pulling bolts.
Anticanman is offline
post #12 of 12 Old 04-17-2013, 11:00 AM
huntinguy
Ya, well that is about to come to an end. Jeeps and wrenches are like Beer and Pretzels
Didn't anyone tell you there are only two kinds of jeeps: those that are coming apart and those that are going together.
I haven't had to do an internal slave before but I have done zillions of external slaves (had to be a Chrysler moron that moved it into the bell housing). They are unusually a pretty straight forward job.
First rule of hydraulic systems is keep in clean.
Second rule of hydraulic systems is keep it clean.
third rule of .... (you get the idea)
take your time, and get some plugs to put in the lines, it will keep everything from getting coated in brake fluid.
huntinguy is offline
