so i got a weird noise... - JeepForum.com
post #1 of 14 Old 04-07-2013, 09:05 PM Thread Starter
BrandonYJReed
lately when I have been driving around I noticed a noise my YJ makes. whenever I let off the gas to shift or coast my jeep makes a whistle type noise until I come to a stop then it goes away, or as soon as I get back on the gas the whistling goes away.. and its not like its doing it constantly and im not hearing it over the jeep, It is only while off the gas. anyone ever had this issue?
-1990 YJ, 2.5L, AX-15, lifted, locked, on 35's.
-1999 XJ, 4.0, AW4, lifted 4.5", JK Rubi take offs.
BrandonYJReed is offline
post #2 of 14 Old 04-08-2013, 10:03 PM Thread Starter
BrandonYJReed
Anyone?
post #3 of 14 Old 04-08-2013, 10:11 PM
GottaYJ
In gear or neutral or both?
1995 YJ Rio Grande 2.5L
GottaYJ is offline
post #4 of 14 Old 04-08-2013, 10:15 PM Thread Starter
BrandonYJReed
Both
post #5 of 14 Old 04-08-2013, 10:21 PM
Reno72
Does it make the noise only while moving, or is it related to engine speed? First thought was vacuum but if it's only while moving that would not be it. Is it more a whistle or a whine?
Reno72 is offline
post #6 of 14 Old 04-08-2013, 10:27 PM
GottaYJ
If only when moving check your front hub assemblies or ujoints. Jack the front tires up and spin them by hand and listen for the noise.
GottaYJ is offline
post #7 of 14 Old 04-08-2013, 10:38 PM Thread Starter
BrandonYJReed
Only when moving. Stops when my jeep does
post #8 of 14 Old 04-08-2013, 10:39 PM Thread Starter
BrandonYJReed
Will do
post #9 of 14 Old 04-10-2013, 04:59 PM Thread Starter
BrandonYJReed
http://youtu.be/iw-uRiSR3wM maybe this will help a little.
post #10 of 14 Old 04-10-2013, 05:04 PM
Chrisnvegas
INFIDEL
Chrisnvegas's Avatar
Interesting. Does it change pitch with rpms or road speed? What if you put it into neutral and coast? Does it seem to be coming from the engine compartment, underneath, right side ect?
Sounded almost something air related. Maybe vacuum
I hate computer updates
Chrisnvegas is offline
post #11 of 14 Old 04-10-2013, 05:19 PM Thread Starter
BrandonYJReed
Stays pretty much same pitch, doesn't really change with RPM's or speed, it does it when in neutral an at a coast, and maybe from the rear of the jeep but hard to tell, could be from the front just as well. The noise stops for the most park when I am on the throttle...
post #12 of 14 Old 04-10-2013, 07:14 PM Thread Starter
BrandonYJReed
Anyone??
post #13 of 14 Old 04-10-2013, 07:30 PM Thread Starter
BrandonYJReed
Okay so it sounds like it might be the seal or something in my SYE housing. I was rolling the jeep around without it running and it was making a kinda squealing noise or something... Could it be the rubber for the seal as the shaft is turning? What can I do to fix this? I'm lost...
post #14 of 14 Old 04-10-2013, 07:42 PM
GottaYJ
Try to get some bearing grease on it.
GottaYJ is offline
