And so it begins......... - JeepForum.com
post #1 of 26 Old 08-12-2011, 08:15 PM Thread Starter
creedua
1997 XJ Cherokee
This evening i was going for a drive in the yj got a couple miles from home and the transfer case started making a loud grinding noise for a little bit stopped, and did it again a few more times before i could get it home. Any ideas?
creedua is offline
post #2 of 26 Old 08-12-2011, 08:16 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Are you sure it's the transfer case?
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 26 Old 08-12-2011, 08:49 PM Thread Starter
creedua
1997 XJ Cherokee
it sounds like it
creedua is offline
post #4 of 26 Old 08-12-2011, 09:05 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
What engine/transmission combo do you have?
Max
Mean Max is offline
post #5 of 26 Old 08-12-2011, 09:09 PM Thread Starter
creedua
1997 XJ Cherokee
Not sure about trans. (5 speed) but the engine is a 258
creedua is offline
post #6 of 26 Old 08-12-2011, 09:22 PM
sacrifice
4.2 and puegot ba-10
granny shifting not double clutchin like I should
'89 YJ Build Thread:
WhyJayPA's '88 Build: http://www.jeepforum.com/forum/f22/mean-green-build-college-budget-1164650/
sacrifice is offline
post #7 of 26 Old 08-12-2011, 09:25 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Originally Posted by sacrifice
puegot ba-10
Here's where I'll place my bet.
Max
Mean Max is offline
post #8 of 26 Old 08-12-2011, 09:29 PM Thread Starter
creedua
1997 XJ Cherokee
the transfer case should be a new process 207, right?
creedua is offline
post #9 of 26 Old 08-12-2011, 09:51 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Should be a NP231
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #10 of 26 Old 08-12-2011, 09:52 PM
sacrifice
np231
post #11 of 26 Old 08-13-2011, 10:50 AM Thread Starter
creedua
1997 XJ Cherokee
Any thoughts as to the problem?
creedua is offline
post #12 of 26 Old 08-13-2011, 11:42 AM
tobias94yj
Hillbilly Member
tobias94yj's Avatar
Max
This is where I would start too , but drain fluids and look for metal. when my D35 turned itself into a full posi I drained the fluid and it looked like metallic paint there was so much metal shavings in there
and if it is your tranny going out do some searching because most people do not go back with that POS peugot tranny. they normally upgrade to a ax-15 or nv-3550 which are better tranny's and are alot more reliable.
To view the NEW
click here!!!
tobias94yj is offline
post #13 of 26 Old 08-13-2011, 05:03 PM
wendell
1987 YJ Wrangler
Yeah 87 was a split year for the 207 or 231 t-case. The 207 isn't a bad case, just a one off deal. Chance's are in favor of it being the BA tranny. It's not if they will break, but when and they are expensive and not worth rebuilding. It will be a great time to install the AX-15. When I purchased my 87 with a 120,000 miles on it, someone had allready swapped in the AX-15. With the BA, it'a just a matter of time. Just driving down the road the t-case don't usaully start makeing noise, tranny's do.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
post #14 of 26 Old 08-13-2011, 05:08 PM
MJMPC
Did you check the t-case and see if it was full of fluid?
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #15 of 26 Old 08-16-2011, 06:17 PM Thread Starter
creedua
1997 XJ Cherokee
Where do i check the fluid in the trans and what fluid do i use if it is low?
creedua is offline
and so it begins p00r0ldjack JK Wrangler Technical Forum 0 03-21-2010 09:52 PM
And so it begins.... SLO_MVR YJ Wrangler Technical Forum 15 08-18-2008 05:35 AM
And it begins... MetZenDS YJ Wrangler Technical Forum 34 08-24-2007 05:55 PM
So it begins... Posey204 YJ Wrangler Technical Forum 2 07-27-2006 01:00 PM
So it begins $$$$! red92YJ YJ Wrangler Technical Forum 1 10-19-2005 06:22 AM
