Snow plow mounting - JeepForum.com
post #1 of 6 Old 07-18-2011, 12:09 PM Thread Starter
dank
Snow plow mounting
Hello,
Could someone chime in to tell me if a 7' Meyer plow would be too heavy for my 95 YJ?, and also if someone has info on the mounting to the Jeep?
Thanks for all responses,
Dan
dank is offline
post #2 of 6 Old 07-18-2011, 03:00 PM
sjwrangler
It should fit. I have the 6.5. Mounts are harder to get for YJs, but sometimes they come up on Ebay. You can try the plowsite.com and search older "Jeep" discussions.
His: 92 YJ 2.5, true-track front/&rear, Meyers plow
Hers: 04 Columbia Edition. 6 cyl., 4" lift, 35s
sjwrangler is offline
post #3 of 6 Old 07-18-2011, 10:51 PM
dodger889
Or make your own.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #4 of 6 Old 07-19-2011, 06:59 AM Thread Starter
dank
snow plow mounting
Yes,
I would be happy to make my own, if I could get some ideas of attachment points at least.
thanks,
dan
dank is offline
post #5 of 6 Old 07-19-2011, 08:51 AM
sjwrangler
http://cgi.ebay.com/ebaymotors/Jeep-...Q5fAccessories
Right from Ebay. Perhaps expensive, but available.
post #6 of 6 Old 07-20-2011, 03:09 PM Thread Starter
dank
snow plow on your YJ
Hi,
Thanks for the responses. I have a pretty good idea of what I need to make now. Basically it's two offset brackets from the Jeep's frame rails down and inwards to fit the mounting kit that I have already.
Thanks again,
Dan
dank is offline
mounting a snow plow dank YJ Wrangler Technical Forum 0 06-26-2011 04:13 PM
Snow Plow Rick22 TJ Wrangler Technical Forum 8 12-22-2010 06:55 PM
Buy a snow plow or a snow blower. That is the question ? wraub TJ Wrangler Technical Forum 3 09-29-2009 01:14 PM
Tj snow plow BEANS TJ Wrangler Technical Forum 23 10-30-2005 06:56 AM
CJ snow plow to fit YJ MAjeep87 YJ Wrangler Technical Forum 1 12-26-2003 04:11 PM
