#1 | |
Snap Ring Pliers for Transmission Rebuild
I am sick of dealing with snap rings with a crappy pair of pliers, so I want to buy a good pair. Could somebody recommend a good tip size for the rings that typically appear in a transmission? Snap-On sells pliers with .038", .047", and .070" tips. Also, would I be better off with the tips at an 18 degree angle or a 90 degree angle?
Thanks in advance.
95 YJ with 2.5L 4 banger engine, BDS 3.5" lift with MORE 5/8" boomerangs Toyo Open Country M/T 33x12.50R15 on Cragar Soft 8 15x8 wheels My Build Thread |
#2 |
ISO 9001 Compliant
I got a pretty good set from Craftsman. I think it was about $40 and came with a few different tips.
might have been this one, but I'm pretty sure I paid more $$ http://www.sears.com/shc/s/p_10153_12605_SPM217386062P?prdNo=93&blockNo=93&bl ockType=G93
. . "The right to be heard does not necessarily include the right to be taken seriously." —Hubert Humphrey . If you live within wheeling distance of San Diego county, click here |
#3 |
You might want to check out the Mac Tool truck.But they got the same snap rings .But might be cheaper.
#4 |
Shiver me Timbers!!!
When I was an equipment tech I always found myself using snap ring plier and getting pissed at the cheapy changable tip ones. Fed up I picked up a set from the first tool truck that rolled into the yard and have never regretted the decision. It was a 12 piece set that included 4 sizes (dont know them off the top of my head) in 3 different angles (straight, 45 and 90). They are called quarter turn because you turn a knob in the middle that allows them to change from internal to external ring types. I spent about $250 on the set.
90 YJ 5.2 Magnum, AX-15, 231 SYE'd D44 front, welded/trussed AMC20HD rear. 4.56 gears soonish. Western 6 lug aluminum wheels, with 35x12.50x15 Wrangler MTRs MYj Build Tube fenders - paused on installing......... 25% completed........... |
#5 |
Where do you find these tool trucks?
#6 | |
When you work as a mechanic/tech, they come by your shop/dealership each week.
![]() ![]() Max ![]()
Click here to see all of my different albums on Photobucket. Choose any album to see all of my pics! Mean Max is setting up his Jeep shop! Picture history of my progress here. Quote:
There is no situation that cannot be improved with a small but well-placed explosive.
#7 |
I found this set:
PRH406, Pliers Set, Retaining Ring, 6 pcs. Would this be overkill or would it be a worthwhile investment? I don't mind spending the money if it would make my life easier...unless I would only need one or two pairs from the set. :/ My only experience with these was a $5 pair from Autozone that caused a lot of cursing and I wound up resorting to using screwdrivers, awls, and duckbilled pliers because the snap ring pliers sucked. I won't be rebuilding transmissions all the time, but when one goes, I'd like to be able to do the job myself. Labor costs around here for rebuilds can reach four digits!
#8 |
Hallowed be thy name....
You don't need a set of snap ring pliers to rebuild our Jeep manual transmissions.
You need a heavy duty lock ring plier. I got mine at Sears (Craftsman) for less than $20. Here is what you are looking for: http://www.sears.com/shc/s/search_10153_12605?keyword=lock+ring+pliers&x=0&y= 0&vName=&viewType=gal&viewItems=24
#9 |
Those are duckbills, he says he already has a set of those. While they are nice, they do not replace snap ring pliers. If he is rebuilding and automatic trans he needs snap ring pliers. There are probably 15-20 snap rings in various sizes in them. Manuals have a snap ring in them as well could benefit from the use of the right tool for the job (any job can for that matter). Having the right tool for the job saves time and frustration. Like they say, it takes money to make money.
#10 |
My bad. I just thought he was talking about manual trannys.
I did not see a single snap ring in my AX5 and I assumed the AX15's would not use them either.
#11 |
The tranny is actually a muncie sm465 manual from a 74 c20 pickup, to clarify. I haven't opened it yet so I'm not 100 percent sure what it has.
#12 | |
I really hope they look like that on the inside. ![]() ![]()
91 YJ 98 XJ 2 door love The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain. |
#13 |
I have these http://www.sears.com:80/shc/s/p_10153_12605_00947386000P?blockNo=1&blockType=G1& keyword=lock+ring+pliers&prdNo=1 and they work really well.
1970 CJ5 (DD) |
#14 |
Saw the edit which negates my statement. No biggie.
#15 | |
Oh they do look like that on the inside. As all of the $15k I have spent inside those things and they will all agree. Oh....................... and did I mention the specials for the day? ![]()
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
