Snap/Pop noise??? - JeepForum.com
post #1 of 12 Old 05-05-2010, 04:44 PM Thread Starter
Mykal101
Snap/Pop noise???
So, when I'm driving my 92 YJ on the street, turn right and hit a curb like when I'm parking in a driveway, I hear this loud pop. I can feel it in the floor boards and not in the steering wheel. I've had my wife drive so I can look for it, but can't see anything. The sound is louder inside the jeep than outside, so I think it's something under the hood. I have put a wrench to every bolt I can find from under the jeep and still can't find it. Anyone have any ideas? It's only when I turn right, and then hit a bump or dip of some sort.
Mykal101 is offline
post #2 of 12 Old 05-05-2010, 04:50 PM
Squamer
Have you checked the body mounts? I had a similar noise when I turned to the right of hit a bump/dip. The right side body mount by the TC support was pulled straight through.
Red Jeep Club: 584 BTW-There are no mechanical problems which cannot be solved through suitable application of high explosives.
JeepLife...all day, every day!
it out. Support your hometown.
Squamer is offline
post #3 of 12 Old 05-05-2010, 05:04 PM Thread Starter
Mykal101
That's a good thought. I'll check and let you guys know. Anyone else have any ideas I can test out?
Mykal101 is offline
post #4 of 12 Old 05-05-2010, 07:23 PM
postaldave
the steering box is known to pop really loud even if it's bolted on tight.
1976 FJ40 aka Yoda Monster
1996 Jeep XJ
Originally Posted by xdgt03 View Post
I removed mine. It is against federal law but so is being an illegal immigrant so...
postaldave is offline
post #5 of 12 Old 05-06-2010, 12:02 AM
Awesome
Mine does the same thing, but usually when I'm turning the wheel hard from post to post while reversing (I back into my driveway).
100 Characters is not enough to have an interesting/relevant signature.
Awesome is offline
post #6 of 12 Old 05-06-2010, 07:03 AM
MJMPC
Have you checked your balljoints?
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #7 of 12 Old 05-06-2010, 08:23 AM
Awesome
Mine are only a couple of years old... I replaced the entire tie rod.
Awesome is offline
post #8 of 12 Old 05-06-2010, 08:46 AM
brunolinski
have you checked the bearings? Mine made ALL kinds of gawd awful noise when it crapped out.
brunolinski is offline
post #9 of 12 Old 05-06-2010, 09:26 AM
ritjobbie
It also could be the leaf packs shifting.
1995 YJ Rio Grande, 2.5L Low Output Engine
ritjobbie is offline
post #10 of 12 Old 05-06-2010, 10:22 AM
ZeroGravity
It could also be your transmission mount is bad, or your battery sliding around.
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #11 of 12 Old 05-06-2010, 10:36 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
I had a noise.... cracked trac bar mount on the frame
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #12 of 12 Old 05-06-2010, 10:40 AM Thread Starter
Mykal101
Checked the body mounts, they all look good. I deleted the trackbars and sway bar, so it's not those mounts.
Mykal101 is offline
Snap Rings for SYE nwiTJdave TJ Wrangler Technical Forum 2 03-21-2009 03:09 PM
Snap! Tomb Raider YJ Wrangler Technical Forum 18 12-11-2007 01:11 PM
Oh Snap - 30 R&P geauxturbo TJ Wrangler Technical Forum 4 09-26-2007 10:38 AM
snap ring greenmachine99 TJ Wrangler Technical Forum 2 06-22-2005 11:36 PM
snap noise from front brakes james985 TJ Wrangler Technical Forum 0 05-03-2005 01:10 AM
