Smoothest 4/5 speed for GM 350? -
Go Back > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Smoothest 4/5 speed for GM 350?
You Pick the Size and Style of Lift Kit. We will Find you RIGID LED Light Blowout Sale - All Sizes, All Series, all FS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 08-25-2015, 02:37 AM   #1
I've got an 87 YJ with a GM 350 and a TH350 transmission. Thing is, I hate having an auto in my "fun ride", and I'm looking to switch back to a four or five speed manual. What would be a smooth-shifting, relatively cheap and easy option?
The AX-15?
FWIW, it'll be on paved streets 99% of the time, so I don't need anything crazy or incorporating granny gears.
BobStrauss is offline   Reply With Quote Quick reply to this message
Unread 08-25-2015, 06:11 AM   #2
1987 YJ Wrangler
For smooth you can go with the medium duty NV3500. It shifts very nice and has good ratios for street driving. If you want something more beefy then the NV4500. I have had both. I love my 4500 for the granny gear and strength, but the 3500 shifted much nicer. The 4 speeds out there will shift like the 4500. You can find SM465's super cheap but its basically a 3 speed on the road due to the granny low. Note that all of these have a 32 spline output. You will need a matching input on your transfer case. Also they have a 6 bolt pattern. You will need to run a chevy transfer case. I run a NP241C transfer case.
1 4.02
2 2.32
3 1.40
4 1.00
5 0.73
R 3.55
NV4500 MT8 variant
1 6.34 (1993) 5.61 (1994 on)
2 3.44
3 1.71
4 1.00
5 0.73
R 6.34 (1993) 5.61 (1994 on)
NV4500 MW3 variant
1 5.61
2 3.04
3 1.67
4 1.00
5 0.73
R 5.61 (to 1997) 5.04 (1997 on)
First Gear - 6.55:1
Second Gear - 3.58:1
Third Gear - 1.70:1 -Sometimes incorrectly listed as 1.57:1.
Fourth Gear - 1.00:1
Reverse - 6.09:1
Related info.
87 YJ, 350 TPI, NV4500, 35x12.50x17, SOA, Locked front, 8.8 LSD rear, Flat skid
87TPIYJ is offline   Reply With Quote Quick reply to this message
In order to be able to post messages on the forums, you must first register.
Jeep, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. is not in any way associated with Jeep or the Chrysler Corp.
