#1 | |
Smoking!!! Ahh!
Okay so today i fixed the leak coming from my water pump. refilled the radiator with coolant/antifreeze/water. I let it run. the leak is fixed buuuuuuuut.... the radiator started smooking
. i let it cool. found that there was some anti-freeze that i spilt on it and thought it was just that vaporating off. but i drove it and it smoked. my temp gauge is at normal running temp for my jeep so im stumped as to wat is going on ![]()
#2 |
H2 Recovery Team Member
run the jeep and get it up to temp and then stop and let it idle while you look around the engine bay. sometimes it takes a little while to evaporate a spill, but if you notice a constant wet spot chances are your rad has a leak. you should be able to trace it though.
RIP: '88 YJ 2.5L Ax-5 NP231 Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front. 92 YJ 4.0L Ax-15 231 5" springs, 1" shackle 31's or 35's depending on my mood |
#3 |
BUILT. NOT BOUGHT.
no biggie. you spilled antifreeze... it'll smoke until it's all gone... which will take a while. just watch your temp gauge and ignore the smoke
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs March 1st, 8pm. WILMINGTON, NC MEET & GREET @ HOOTERS! |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
