Smoke under the hood - JeepForum.com
post #1 of 4 Old 11-28-2001, 03:07 PM Thread Starter
Brendan
I know that sounds stupid, but I don't have a clue what it could be. I don't think I'm burning oil. I just cleaned my valve cover and put a new gasket in. What else could it Be?
Duvie
95 YJ 2.5L 5 Speed
Fightin a war against Florida Rust!
Brendan is offline
post #2 of 4 Old 11-28-2001, 03:25 PM
Big92Jeep
If you just repalce your valve cover gasket it could be residue on the manifold. I bet is smells good . If you can't find it clean your engine with some degreaser (gunk) and then look for leaks.
~Rick
2008 Unlimited Rubicon
"The weather is here, I wish you were beautiful"
Big92Jeep is offline
post #3 of 4 Old 11-30-2001, 08:31 AM
glm 87 wrangler
Just make sure it does not smell like wires!
Mine caught fire one time! Dont know what happen just cost 300 bucks to rewire.
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
post #4 of 4 Old 12-04-2001, 05:24 PM
Morgster
Here's an idea...If you have a stock air cleaner setup, look inside to see if oil is backing up inside. Some times the pcv and hose gets plugged and oil blow by builds here and eventually drips down on to the manifold or exhaust, causing a burning smell that drives you nuts. If you have this problem, start the motor, remove the pcv valve, spray it out with gumout and spray inside the hose going to the base of the carb to clean out the small orifice inside the hose. This will allow proper vacuum in this hose, make the pcv valve work properly, eliminate oil into the air cleaner, stop the dripping, and remove the smell. Have fun looking.. Mike
Morgster is offline
Hood Bug Deflector - Worth it?? Drilling in Hood?? DekX TJ Wrangler Technical Forum 44 11-03-2011 09:16 PM
jeep highline hood info CJ hood on a tj sail78385 Wrangler General Discussion 2 11-08-2010 12:35 AM
Hood prop or lay the hood right back on the windsheild frame? Jeeeeeeeeeeeeep YJ Wrangler Technical Forum 27 01-29-2010 04:55 PM
Grill to hood seal- does your hood shake on the hwy? P35A JK Wrangler Technical Forum 7 07-23-2007 08:46 AM
Newb - Hood Latches - hood moves. Hollywood TJ TJ Wrangler Technical Forum 25 03-16-2007 11:04 AM
