Smoke Under the Hood - JeepForum.com
post #1 of 11 Old 04-05-2011, 05:17 PM Thread Starter
89WhyJ
I don't have my YJ on the road yet, but I start it in the garage about once a week and let it run for a while. Usually, when I shut it down after letting it run for about 15 mins, I can notice some white smoke coming out from around/under the intake manifold and have a heavy smell of exhaust fumes. I have to assume the smoke is coming from the exhaust manifold beneath the intake, but I can't see from where exactly. Today, I let it run for a bit longer than usual. After about 20 mins or so, the fumes in the garage were fairly strong, so I shut it down and checked out under the hood. The white smoke was coming from the same area, but also from around the water pump. It looked as if it were coming from where the lower radiator hose attaches to the pump (of course that doesn't make any sense to me). I know there is a very slight leak of coolant around the thermostat gasket (PO didn't seal it well).
So, I guess my questions are revolving around the smoke. Has anyone else had these experiences, or know where I should start looking for a solution? There is no smoke coming out of the exhaust pipe, only under the hood. And both locations smoke for several minutes after I shut the engine off. Thanks guys!
89WhyJ is offline
post #2 of 11 Old 04-05-2011, 05:58 PM
MJMPC
You are running this thing with the garage door open........... right??
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #3 of 11 Old 04-05-2011, 06:08 PM
mbates96
so i had two smoking situations. I had a wire loom that started to melt by touching the to close to the intake/exhaust manifolds - easy to find. Also I had some sticker/tape residue on my new exhaust and that would smoke once it heated and up and it would come up all over the place in the engine bay
mbates96 is offline
post #4 of 11 Old 04-05-2011, 06:25 PM
moonshinefuel
You do let it sit for long periods of time it sounds like. To be a little candid here, and throw out a possibility, maybe a small critter, or critters are/have crawled up in there somewhere, and nesting material, and now they are crispy critters. (Just a possibility)
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #5 of 11 Old 04-05-2011, 06:55 PM Thread Starter
89WhyJ
Definitely.
I hadn't thought about the critter issue, but its basically been garage bound for the past 1.5 years. I'll have to check to see if there is anything too close to the manifold getting burned/melted.
89WhyJ is offline
post #6 of 11 Old 04-05-2011, 07:47 PM
danthman
1987 YJ Wrangler
try reving it up to see if it clears. if you have a high mile engine it could be just oil buildup burning off or maybe just running alittle rich. now did you happen to smell a sweet smell other than the exhaust? that would be coolant steaming off of something...
"money talks, mine always says goodbye"
danthman is offline
post #7 of 11 Old 04-06-2011, 08:11 AM
vadslram
White smoke or steam? Coolant leak onto the manifold would look like white smoke and show up after running the engine up to temp. Any drips anywhere?
vadslram is online now
post #8 of 11 Old 04-06-2011, 09:44 AM
WhyJayPA
X2...my yj has been sitting and any type of oil leak from the valve cover will burn off and smoke. Mine burnt off for a while until I changed valve cover gaskets and cleaned everything up. Exhaust smell might seem strong just because you are running it in your garage even with the door open
Sent from my Droid using JeepForum
WhyJayPA is offline
post #9 of 11 Old 04-06-2011, 09:52 AM
doherty80
i would say start with one thing at a time. drain the coolant and fix your radiator hoses and the thermastat housing gasket. thats a 20 dollar fix. then after that sitution is cleared the smoke from the linking thermostat wont be throwing off your view of whatever is going on around your intake.
1990 Jeep Wrangler Laredo 4.2L L6 5spd Weber 32/36 3inbl, 32" MT, hella500 light bar selling cj yj plow pm for details
|_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)
doherty80 is offline
post #10 of 11 Old 04-06-2011, 10:16 AM
sacrifice
QFT. Get that fixed and go from there. I would give the bay a good look from all sides and angles to see if there is anything strange. If nothing give it a good cleaning, watch your electronics. See where that gets you
granny shifting not double clutchin like I should
'89 YJ Build Thread:
WhyJayPA's '88 Build: http://www.jeepforum.com/forum/f22/mean-green-build-college-budget-1164650/
sacrifice is offline
post #11 of 11 Old 04-06-2011, 12:22 PM Thread Starter
89WhyJ
Good point guys. Since it has that plastic valve cover, the gasket was leaking. I fixed that (as good as can be done) and I thought all the oil had burned off by now...but maybe not. I'll take care of the thermostat leak and then look for oil leaking onto the manifold. I was just worried there could be something else (much worse) possibly going on there.
89WhyJ is offline
White Smoke Under Hood Kraigers1 WJ Grand Cherokee Forum 25 06-18-2017 10:59 PM
Oh no white smoke pooring out from under my hood Teupow TJ Wrangler Technical Forum 22 02-21-2011 08:46 PM
08 CRD, Burning plastic smell and smoke from under hood! no-blue-screen WK Grand Cherokee & XK Commander Forum 13 01-01-2009 03:34 PM
'02 WJ 4.0 - Smoke From Under Hood @ Stop? lawdogg ZJ Grand Cherokee Forum 13 09-26-2007 05:33 AM
Smoke under the hood Brendan YJ Wrangler Technical Forum 3 12-04-2001 05:24 PM
