smog pump compressor for onboard air? - JeepForum.com
post #1 of 6 Old 04-25-2008, 05:40 PM Thread Starter
sitdwnandhngon
1987 YJ Wrangler
i really would like to make myself an onboard air compressor from an A/C compressor, but i dont know what i did with the one i pulled from my truck. However i found a smog pump that is used to pump fresh air into the exhaust. Does anyone know if this would have enough psi to bother converting, or what the duty cycle would be, i imagine its 100%.
I can't bear the thought of losing, I dread the attention winning brings
Originally Posted by northjeep View Post
4.2 has 0.2 more!
sitdwnandhngon is offline
post #2 of 6 Old 04-25-2008, 05:52 PM
pat8942
pat8942's Avatar
No it won't work because it won't create much pressure and it won't provide much CFM either.
All other things being equal, the simplest solution is the best.
Ich liebe meinen Jeep!
pat8942 is offline
post #3 of 6 Old 04-25-2008, 06:32 PM Thread Starter
sitdwnandhngon
1987 YJ Wrangler
thats what i was afraid of. So does anyone know of york (thats the kind with and oil resivoir right?) i can find that might bolt right up to the 258 engine. Something from a ford maybe.
4.2 has 0.2 more!
post #4 of 6 Old 05-15-2008, 08:11 AM
Minister
1987 YJ Wrangler
If you have the 258, go out and look for a AMC Pacer or an AMC Eagle with AC, they have the York compressor, you'll need the compressor, the bracket, pulleys and maybe the alternator mount, I don't remember excacty all the parts, but compare between your jeep and the donor what you are missing, then pull what you need..
"I feel sorry for people who do not drink. When they wake up in the morning it is as good as they are going to feel all day."
Frank Sinatra
"Before beginning a Hunt, it is wise to know what you are looking for before you begin looking for it."
Winnie-the-Pooh
Minister is offline
post #5 of 6 Old 05-15-2008, 05:16 PM Thread Starter
sitdwnandhngon
1987 YJ Wrangler
awesome, i forgot all about this thread, good info thanks.
4.2 has 0.2 more!
post #6 of 6 Old 05-15-2008, 05:28 PM
Minister
1987 YJ Wrangler
No problem, If I remember it right, you'll need the thermostat housing on the donor car too.
Frank Sinatra
Winnie-the-Pooh
Minister is offline
Air bed pump = onboard air compressor? HolidayJeep TJ Wrangler Technical Forum 9 02-02-2007 03:42 PM
Onboard compressor installation. MeGAMoE TJ Wrangler Technical Forum 5 09-24-2006 08:15 AM
Onboard air with a stock a/c compressor? YJ 4.2L hmk_21 YJ Wrangler Technical Forum 1 12-22-2004 03:17 PM
Onboard Air compressor Question jsol95 TJ Wrangler Technical Forum 4 08-15-2004 07:29 PM
Electric Onboard Air Compressor Jeepaudi TJ Wrangler Technical Forum 8 09-14-2003 08:49 AM
