Smog pump? - JeepForum.com
post #1 of 18 Old 05-29-2010, 08:22 PM Thread Starter
jeep_maniack
Smog pump?
Hey guys I was wondering.... How can i tell if my jeep has a smog pump? Or can you tell me right off?
My jeep is a 5 speed carbureted 4.2 liter straight six with the stock intake,
1989 yj wrangler...
What else do you need to know?
Thanks!
..l_______
./l ,[_0_0_],
.l----L -[]lllllll[]-
()_)=o()_)=o=)_)__-_-__-__-_-___
jeep_maniack is offline
post #2 of 18 Old 05-29-2010, 08:25 PM
Living_High
The '89 I-6 did not have a smog pump, it used the air pulse system instead. Look at the top rear of your valve cover. You should see a bank of three solenoids on a bracket. Also, on the passenger side, there will be two largish tubes that connect to the air filter and then connecting to the exhaust.
I did the Howell upgrade and ditched my air pulse system and the jeep runs a hell of a lot better.
Living_High is offline
post #3 of 18 Old 05-29-2010, 08:39 PM
yellow2kgt
X2. No smog pump just the pulse air. We do not have emissions tests so I removed all of the pulse air stuff on my YJ and crimped the nipple at the cat. Although, technically with the Howell kit I am still legal.
1990 Jeep YJ 4.2
Howell EFI, BDS 3.5" lift, M.O.R.E 5/8" Boomerang shackles, 1" Daystar BL, 1" JKS MML, TFI, Crager soft 8s w 35" Dunlop Mud Rovers, Ford 8.8, 4.88s, Dana 30 E-Locker, Terra Flex SYE, Tom Woods CV shaft, Warn M8000.
yellow2kgt is offline
post #4 of 18 Old 05-29-2010, 09:36 PM Thread Starter
jeep_maniack
Thanks guys!! That's just what I needed to know! I appreciate all of the help...
Also, how can I get rid of the whole stock intake while keeping it legal? I hate the whole idea of how complicated the stock intake system is and I want to just make it simple and i can see it running way better without it.. How much would it cost?
Thanks!
..l_______
./l ,[_0_0_],
post #5 of 18 Old 05-29-2010, 09:41 PM
Living_High
Stock intake, are you referring to the carb? If so, the Howell EFI kit will run around $1200 or so for everything you need, minus a few items that are not expensive at all. I installed the kit in about 8 hours. Just read and reread the instructions, before starting but the kit is well worth it.
Also, in Utah, do you have emission tests?
post #6 of 18 Old 05-29-2010, 10:02 PM Thread Starter
jeep_maniack
Yeah we do... We had to mess with the carb setting and make them really weird so that now the jeep is not running as good as it could be. I think we are losing economy and performance because of it... Maybe it's something I'll have to look into..
And yeah I'm talking about the air intake (everything from the filter to the carb)..
Thanks!
..l_______
./l ,[_0_0_],
post #7 of 18 Old 05-29-2010, 10:09 PM
Living_High
We have pretty stringent emission test here in Colorado too. I was having trouble with the carb as well. When I installed my Howell kit, the jeep ran much better and i pass my emission tests with flying colors every time. When you install the Howell, you are also doing a nutter bypass, since the old ECM is tossed, in favor of the new ECM for the Howell.
post #8 of 18 Old 05-30-2010, 12:28 PM Thread Starter
jeep_maniack
Yeah sounds like it might be worth it for a daily driver... Do you guys know of any other ways that I might be able to get rid off the pulse air system and keep it legal? I kind of want to do a simple K&N filter on top or something and that's it... But I don't know if that would be legal.
I am rebuilding my jeep soon and so I am just seeing what else I might be able to do to make it perform better and get better economy and last longer and all that so I can do it all in one shot.
Thanks guys!
..l_______
./l ,[_0_0_],
post #9 of 18 Old 05-30-2010, 02:52 PM
Karma
HI,
Yep. From one '89 owner to another, go with the Howell. While I finally got my original Caarter BBD carb running well in its stock configuration, it had major trail limitations. The Howell kit solved all my issues. As said above, it's well worth the money.
Sparky
Karma is offline
post #10 of 18 Old 05-30-2010, 05:34 PM Thread Starter
jeep_maniack
Alright good to know! I'll definitely look into it!
Thanks!
..l_______
./l ,[_0_0_],
post #11 of 18 Old 05-30-2010, 06:54 PM Thread Starter
jeep_maniack
Can somebody please give me a link to one of these howell kits/ i cant seem to find one using google...
Thanks!!
..l_______
./l ,[_0_0_],
post #12 of 18 Old 05-30-2010, 07:17 PM
Living_High
post #13 of 18 Old 05-30-2010, 07:20 PM Thread Starter
jeep_maniack
Alright looks good! Thanks a bunch! I appreciate the help.. I really am starting to consider it. once i rebuild the jeep, if i add this then i can see my jeep doing wonders :-). It could be an amazing jeep! haha...
Thanks!
..l_______
./l ,[_0_0_],
post #14 of 18 Old 05-30-2010, 07:25 PM
Living_High
I noticed a marked improvement when I installed the Kit. I used to stall on the trail when I got into some sloped trails and the card would either starve or flood. With the EFI conversion, I have never had a problem. I know the price is a bit expensive and it took me a bit to finally pony up the change and purchase it... I would do the same thing again. The vacuum lines that get tossed alone are definitely worth the price as well.
post #15 of 18 Old 05-30-2010, 09:06 PM
Karma
Thanks!
HI,
Without in any way knocking the Howell kit down (see my post above), you should have reasonable expectations. I will try to help with this.
1. I did not notice any increase in power.
2. Gas milage did not improve or if it did, very little.
But there were many things that did improve.
1. No stalling at extreme angles.
2. Starts easily any time, everytime in any weather at any angle.
3. Engine runs beautifully all the time.
4. No idle problems.
5. Engine will run well below idle speed with power. Great if you have low gears. Effectively increases your crawl ratio by running at the lower RPM.
6. Very reliable shotgun starting. In case you don't know what this is, I understand. I made the term up. It is a starting technique I use very often in low range. I simply leave the clutch out and in low gear/low range, hit the starter with your foot off the gas pedal. The engine starts very smoothly and your Jeep starts moving slowly and smoothly. No riding the clutch. It is a great way to start on a steep hill (ether up or down). The fuel injection works for this very well. It is so effective that I rarely use the clutch when starting in low range. It's a trick that many folks don't seem to know about.
So, this is my addition to trail technique and lore: SHOTGUN STARTING
Sparky
Karma is offline
smog pump compressor for onboard air? sitdwnandhngon YJ Wrangler Technical Forum 5 05-15-2008 05:28 PM
YJ Smog Pump Suggestions krats82 YJ Wrangler Technical Forum 9 04-19-2008 10:41 AM
smog? The Punisher YJ Wrangler Technical Forum 3 02-06-2007 06:02 PM
SMOG Help PLEASE... timatoe YJ Wrangler Technical Forum 13 11-13-2006 06:23 PM
anyone have a smog pump diagram (urgent) 5windowcoupe YJ Wrangler Technical Forum 1 04-24-2004 10:23 PM
