Smog disabled 1990 YJ - JeepForum.com
post #1 of 3 Old 02-25-2009, 04:20 PM Thread Starter
AidanMullen
Hey all,
So far I'm enjoying my membership here. Lots of useful info, thanks! Can anyone tell me if a '90 YJ is computer controller or not? This one I bought has had most of it's smog related gear pulled out or disabled, and I'm not sure where to start. I'm considering a new carb/intake manifold/header combination. There are no smog regs where I live. Anyone have any suggestions?
AidanMullen is offline
post #2 of 3 Old 02-25-2009, 04:34 PM
Burnerman
Burnerman's Avatar
Take a picture of the carb and engine and post a link. All the 4.2's had a computer controlled emission system. Read all about the workings here..LINK. It can run very nicely with most of the stuff removed.. Search Nutter Bypass....
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #3 of 3 Old 02-25-2009, 04:35 PM
No_Return
As long as you are positive that you have no emissions restrictions you can rip it all off. This is a very popular topic here on YJ - JF. But if you ever move or sell it in another state you may find that you can't get it registered an almost everything has to be put back on.
Do a search for "Emissions YJ? you will find dozens of threads.
As far as computer controlled... yes you have it on a 1990 but you can all but eliminate it by doing the "Nutter bypass" If you have a stock Carter Carb there are a few extra steps related to modding the carb, any other aftermarket Carb and the Nutter is a must do.
The biggest pitfall to removing all the stuff is vacuum leaks. Pay close attention to the details.
One does not establish a dictatorship in order to safeguard a revolution; one makes a revolution in order to establish a dictatorship. - Orwell
No_Return is offline
1990 xj 4.0 into 1990 yj finishing where someone left off moparcory617 YJ Wrangler Technical Forum 4 10-11-2009 02:41 PM
Does CA smog Ref need to see VSS? Evdog89 YJ Wrangler Technical Forum 7 09-22-2009 08:06 AM
Fuel Pump - Disabled? Nuge TJ Wrangler Technical Forum 3 04-10-2009 01:49 PM
AED disabled my security key..?! minileprechaun TJ Wrangler Technical Forum 16 02-15-2008 06:44 AM
1990 YJ 4.2 Conversion Calif. SMOG!! rcpeters YJ Wrangler Technical Forum 2 08-19-2004 10:15 AM
