smittybilt windshield hinges...door doesnt fit back on? - JeepForum.com
post #1 of 8 Old 03-19-2014, 11:59 AM Thread Starter
ufvj217
I have these smittybilt hinges, and since putting them on, I cant seem to get my half doors back on. It hits the upper bolt, since the replacement bolts dont sit flush with the hinge like the oem torx bolts did.
http://www.4wheelparts.com/Exterior-...FWuhOgod5G0Ayw
This bolt:
ufvj217 is offline
post #2 of 8 Old 03-19-2014, 12:22 PM
roadyrob
1987 YJ Wrangler
get a countersunk bolt.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #3 of 8 Old 08-30-2014, 01:44 AM Thread Starter
ufvj217
I know this thread is old, but I'm bumping to see if anyone else runs these and has this issue before I take all the bolts off again (it wasn't exactly easy getting behind the dash to get them off).
ive just been running doorless all this time since I can't get the doors on
ufvj217 is offline
post #4 of 8 Old 09-01-2014, 02:30 PM
zombiedave
I have the same problem. those buttonhead bolts are stupid. I left that bottom bolt out for now and put in one of those plastic door panel plugs. I'm thinking the holes are going to have to be tapered but what worries me is that the metal is so thin, tapering might not give much for the bolt to hold on to
zombiedave is offline
post #5 of 8 Old 09-01-2014, 02:35 PM
Steve707
If you have a drill you can get a counter sink then a couple counter sunk bolts. That's how the original hinges are set up.
Steve707 is offline
post #6 of 8 Old 09-01-2014, 03:18 PM
zombiedave
well that's a relief, I didn't know they sold drill bits to do that! still learning here haha. I bought all new bolts that are just like the original except with a hex instead of those awful torx. just sucks having to spend more money when I probably could've just bought the crown replacement that is already tapered
post #7 of 8 Old 09-01-2014, 05:50 PM
IA93Javert
You will learn a ton here. Search and then ask you will find everything you need.
IA93Javert is offline
post #8 of 8 Old 09-01-2014, 06:02 PM Thread Starter
ufvj217
Yea I need to countersink mine I guess.
ufvj217 is offline
